Making maps with the help of small UAVs seems to be easy enough. However, when geometric accuracy is critical, how do you determine and state the estimated accuracy of your mapping product? One way is to establish a test bed with a redundancy of accurately surveyed check points which are used as independent bench marks against which the map can be compared. In this picture we show a comparison between high accuracy GPS derived check point coordinates and corresponding coordinates as derived from our 3D model. Note that for illustration purposes the horizontal errors were scaled by a factor of 1000.
The 3D model was created from 261 aerial images (13mm GSD) captured by a Sony a6000 camera with 16mm fixed lens. The camera was carried by a Pixhawk equipped modified Steadidrone quadcopter. The flying time was 10 minutes and, using our V-Map system (http://www.microaerialprojects.com/v-map/ ), we could accurately survey the 12 ground control points in about 15 minutes.
Using 105 check points in our error analysis we can now confidently claim that when we map similar terrain with this particular method we can realistically expect to achieve the following accuracy:
Horizontal approximate circular error at 95% confidence 0.028m
Vertical Accuracy at 95% confidence: 0.039m
Not bad, especially when considering that the 4.75ha map can be delivered the very next day after image acquisition.
Comment by me on February 19, 2015 at 9:10pm
@Walter,
Very interesting. Have you run any tests in tall grass or another non-hard landcover? You essentially tested absolute accuracy of the system but my guess is that both horizontal and vertical accuracy radically decreases in a tall vegetation. I've done a lot of research and my thesis looking at LIDAR accuracy in tidal wetlands and even with lasers we struggle to find the ground surface.
Comment by Rami Kopelman on February 25, 2015 at 1:46pm
How do you set the A6000 focus during missions?
Comment by SkySight on April 1, 2015 at 1:26pm
Hi Diydrones members,
We would like to introduce you to our new SkySight family – trigger cables designed to enhance your UAV experience by simplifying the camera control for your Sony MultiPort™ equipped cameras. SkySight connects Sony cameras to your autopilot or R/C system, eliminating the need for a separate interface system.
The first release in the family of SkySight products - "MONO"
MONO is very user friendly and easy to install.
SkySight products reflect:
  • High quality
  • Lightweight design
  • Simplistic use
MONO is a smart, lightweight solution and first of its kind to be compatible with the most recent Sony interface – MultiPort™.
Furthermore it supports a total of 4 different trigger modes, to suit your needs the best.
MONO supports Sony models from 2012 and onwards, that utilizes the proprietary Sony MultiPort™ connector.
More camera brands will be supported in the near future.
Please visit our store by clicking the link below and get a glance at our new product.
http://SkySight.eu/
* Get 15% off your purchase with this promotion coupon until 30. April 2015
Coupon: MONO15
* Coupon applies to one unit pr. Customer.
Best regards – the SkySight Team!
www.SkySight.eu
...Sight from above
Comment by Jim Peterson on April 14, 2018 at 5:39pm
As always, very nice work Walter!
Comment
