Here is my solution to access 6 flight modes on Graupner MZ24 transmitter.
As described in ColinBouriquet's blog, also two swithes has to be activated on MZ24 to manage 6 modes.
The idea is to make the tx send the following to the receiver to activate the 6 modes:
Mode 1:  PWM: 0-1230
Mode 2:  PWM: 1231 - 1360
Mode 3:  PWM: 1361 - 1490
Mode 4:  PWM: 1491 - 1620
Mode 5:  PWM: 1621 - 1749
Mode 6:  PWM: 1750 -
  1. Activare Base
    1. Activate Channel set
    2. Push # 5. Aux 1 (the channel which controls the modes)
      You will then see the Select - No - Clr picture
    3. Activate the chose switch. I have used  Sw 5
      On the left top of the tx.
      Initially, the tx will send these PWMs to the receiver:
      Switch far back: 1165
      Switch miiddle: 1504
      Switch forward: 1817
  2. Activate Base again
      1. Activate SW7 to channel 9
  3. Activate Function
    1. Activate Prog mix
      1. Mix Channel 9 to Channel 5
      2. Hit the >> button.
      3. Adjust the mixing image like this
  4. The movement of the switches will then give this result
You the can access all 6 modes.. Now go to Mission planner an allocate the your chosen modes to the 6 modes you created.
Comment by Jaimie Fryer on April 8, 2015 at 10:41am
You just saved me a lot of tx battery charging. This is very appreciated. Thanks!
Comment by Adriano on June 25, 2015 at 2:18pm
is there any specific thresold for the travel that I have to set?? following your same steps I got different value and finally not abble to switch between all modes...
any suggestion??
Comment by Espen Bakke on June 25, 2015 at 11:11pm
I haven't done anything to thresholds.
What happens when you follow the above instructions?
Have a look at the servo screen in your tx and see what happens when you flip the switches.
Comment by Adriano on June 27, 2015 at 1:36am
this is strange because if I don't touch the threshold I got 1105ms instead of 1165, 1505 and 1906 insted of 1817.
then I copy exact your configuration, but the results are compleatelly out of range
I finally managed a different configuration that works:
I set AUX 1 to SW5
AUX 5 to SW6
then E.P.A. threshold to CH5 +/- 32%
A -125%  B-125%
Offset Y +4%
this is only way I can get 6 modo correctly switching....
Comment by hüseyin yıldız on July 7, 2016 at 9:32am
another solution
I set AUX 1 to SW3
AUX 5 to SW6
E.P.A. -/+ travel  to CH5 32%
Subtrim ch5 +%34
A +125%  B +125%
Offset Y  -98%
