Building, flying and crashing a large QuadPlane
Not all of the adventures that CanberraUAV have with experimental aircraft go as well as we might hope. This is the story of our recent build of a large QuadPlane and how the flight ended in a crash.
As part of our efforts in developing aircraft for the Outback Challenge 2016 competition CanberraUAV has been building both large helicopters and large QuadPlanes. The competition calls for a fast, long range VTOL aircraft, and those two airframe types are the obvious contenders.
This particular QuadPlane was the first that we've built that is of the size and endurance that we thought it would easily handle the OBC mission. We based it on the aircraft we used to win the OBC'2014 competition, a 2.7m wingspan VQ Porter with a 35cc DLE35 petrol engine. This is the type of aircraft you commonly see at RC flying clubs for people who want to fly larger scale civilian aircraft. It flies well and the fuselage and is easy to work on with plenty of room for additional payloads.
VQ Porter QuadPlane Build
The base airframe has a typical takeoff weight of a bit over 7kg. In the configuration we used in the 2014 competition it weighed over 11kg as we had a lot of extra equipment onboard like long range radios, the bottle drop system and onboard computers, plus lots of fuel. When rebuilt as a QuadPlane it weighed around 15kg, which is really stretching the base airframe to close to its limits.
To convert the porter to a QuadPlane we started by glueing 300x100 1mm thick carbon fibre sheets to the under-surface of the wings, and added 800x20x20 square section carbon fibre tubes as motor arms. This basic design was inspired by what Sander did for his QuadRanger build.
in the above image you can see the CF sheet and the CF tubes being glued to the wing. We used silicon sealant between the sheet and the wing, and epoxy for gluing the two 800mm tubes together and attaching them to the wing. This worked really well and we will be using it again.
For the batteries of the quad part of the plane we initially thought we'd put them in the fuselage as that is the easiest way to do the build, but after some further thought we ended up putting them out on the wings:
They are held on using velcro and cup-hooks epoxied to the CF sheet and spars, with rubber bands for securing them. That works really well and we will also be using it again.
The reason for the change to wing mounted batteries is twofold. The first is concerns of induction on the long wires needed in such a big plane leading to the ESCs being damaged (see for example http://www.rcgroups.com/forums/showthread.php?t=952523&highligh...). The second is that we think the weight being out on the wings will reduce the stress on the wing root when doing turns in fixed wing mode.
We used 4S 5Ah 65C batteries in a 2S 2P arrangement, giving us 10Ah of 8S in total to the ESCs. We didn't cross-couple the batteries between left and right side, although we may do so in future builds.
For quad motors we used NTM Prop Drive 50-60 motors at 380kV. That is overkill really, but we wanted this plane to stay steady while hovering 25 knot winds, and for that you need a pretty high power to weight ratio to overcome the wind on the big wings. It certainly worked, flying this 15kg QuadPlane did not feel cumbersome at all. The plane responded very quickly to the sticks despite its size.
We wired it with 10AWG wire, which helped keep the voltage drop down, and tried to keep the battery cables short. Soldering lots of 10AWG connectors is a pain, but worth it. We mostly used 4mm bullets, with some HXT-4mm for the battery connectors. The Y connections needed to split the 8S across two ESCs was done with direct spliced solder connections.
For the ESCs we used RotorStar 120A HV. It seemed a good choice as it had plenty of headroom over the expected 30A hover current per motor, and 75A full throttle current. This ESC was our only major regret in the build, for reasons which will become clear later.
For props we used APC 18x5.5 propellers, largely because they are quite cheap and are big enough to be efficient, while not being too unwieldy in the build.
For fixed wing flight we didn't change anything over the setup we used for OBC'2014, apart from losing the ability to use the flaps due to the position of the quad arms. A VTOL aircraft doesn't really need flaps though, so it was no big loss. We expected the 35cc petrol engine would pull the plane along fine with our usual 20x10 prop.
We did reduce the maximum bank angle allowed in fixed wing flight, down from 55 degrees to 45 degrees. The aim was to keep the wing loading in reasonable limits in turns given we were pushing the airframe well beyond the normal flying weight. This worked out really well, with no signs of stress during fixed wing flight.
Test flights
The first test flight went fine. It was just a short hover test, with a nervous pilot (me!) at the sticks. I hadn't flown such a big quadcopter before (it is 15kg takeoff weight) and I muffed up the landing when I realised I should try and land off the runway to keep out of the way of other aircraft using the strip. I tried to reposition a few feet while landing and it landed heavier than it should have. No damage to anything except my pride.
The logs showed it was flying perfectly. Our initial guess of 0.5 for roll and pitch gains worked great, with the desired and achieved attitude matching far better than I ever expected to see in an aircraft of this type. The feel on the sticks was great too - it really responded well. That is what comes from having 10kW of power in an aircraft.
The build was meant to have a sustained hover time of around 4 minutes (using ecalc), and the battery we actually used for the flight showed we were doing a fair bit better than we predicted. A QuadPlane doesn't need much hover time.  For a one hour mission for OBC'2016 we reckon we need less than 2 minutes of VTOL flight, so 4 minutes is lots of safety margin.
Unfortunately the second test flight didn't go so well. It started off perfectly, with a great vertical takeoff, and a perfect transition to forward flight as the petrol engine engaged.
The plane was then flown for a bit in FBWA mode, and it responded beautifully. After that we switched to full auto and it flew the mission without any problems. It did run the throttle on the petrol engine at almost full throttle the entire time, as we were aiming for 28m/s and it was struggling a bit with the drag of the quad motors and the extra weight, but the tuning was great and we were already celebrating as we started the landing run.
The transition back to hover mode also went really well, with none of the issues we thought we might have had. Then during the descent for landing the rear left motor stopped, and we once again proved that a quadcopter doesn't fly well on 3 motors.
Unfortunately there wasn't time to switch back to fixed wing flight and the plane came down hard nose first. Rather a sad moment for the CanberraUAV team as this was the aircraft that had won the OBC for us in 2014. It was hard to see it in so many pieces.
We looked at the logs to try to see what had happened and Peter immediately noticed the tell tale sign of motor failure (one PWM channel going to maximum and staying there). We then looked carefully at the motors and ESCs, and after initially suspecting a cabling issue we found the cause was a burnt out ESC:
The middle FET is dead and shows burn marks. Tests later showed the FETs on either side in the same row were also dead. This was a surprise to us as the ESC was so over spec for our setup. We did discover one possible contributing cause:
that red quality control sticker is placed over the FET on the other side of the board from the dead one, and the design of the ESC is such that the heat from the dead FET has to travel via that covered FET to the heatsink. The sticker was between the FET and the heatsink, preventing heat from getting out.
All we can say for certain is the ESC failed though, so of course we started to think about motor redundancy. We're building two more large QuadPlanes now, one of them based on an OctaQuad design, in an X8 configuration with the same base airframe (a spare VQ Porter 2.7m that we had built for OBC'2014). The ArduPilot QuadPlane code already supports octa configs (along with hexa and several others). For this build we're using T-Motor MT3520-11 400kV motors, and will probably use t-motor ESCs. We will also still use the 18x5.5 props, just more of them!
Strangely enough, the better power to weight ratio of the t-motor motors means the new octa X8 build will be a bit lighter than the quad build. We're hoping it will come in at around 13.7kg, which will help reduce the load on the forward motor for fixed wing flight.
Many thanks to everyone involved in building this plane, and especially to Grant Morphett for all his building work and Jack Pittar for lots of good advice.
Building and flying a large QuadPlane has been a lot of fun, and we've learnt a lot. I hope to do a blog post of a more successful flight of our next QuadPlane creation soon!
Comment by Andrew Tridgell on March 4, 2016 at 2:29am
@Iskess,
I agree that aiming for 50% throttle in hover is excessive for most quadplanes. For my next build I'm aiming for 65%, using ecalc to do all the work of trying different motor/prop/battery combinations.
To reduce weight for the octaquad build of the porter we're building now I have spent a lot of time looking at the power to weight ratio of the motor/esc combinations. The t-motor motors seem particularly good for this.
Another thing to watch out for is the angle of the quad motors. You can get a problem where the angle of attack to start getting enough lift on the wing is enough that the quad motors are pointing back sufficiently to prevent the plane getting up to speed. Angling the quad motors a few degrees forward should help a lot. It means it will tend to drift forward in QHOVER, but you can always use QLOITER if you want to hold position.
Also note that if you do angle the motors forward then if you try to go backwards at anything but a very low speed in copter mode then the drag from the wing will be really bad, and could increase motor current a lot.
Cheers, Tridge
Comment by Jure M on March 4, 2016 at 2:32am
I'm building a tricopter/plane hybrid from X8 flying wing. And one thing that I don't want to happen is to have to redesign everything because I chose to use components with inadequate power. So for planned weight of ~6 kg there will be three tilt motors with ~5 kg thrust each. And by tilting them the drag will be reduced and there will be no dead weight on the plane.
Comment by Cala on March 4, 2016 at 5:10am
Justin L: can you post some photos from your Skywalker? Thank's.
Comment by iskess on March 4, 2016 at 5:50am
Tridge,
Thank you for your reply. Are you determining the rotor tilt angle based on the wings AOA near stall, or at cruise flight? What method are you using to build in the tilt? Are you tilting the whole boom to the wing, or just the motors to the boom?
I want to make sure I don't cause windmilling while in cruise by adding too much tilt. I noticed that there is no prop brake in BLheli, at least that I could find. Does anyone know of a way to brake the motor when the throttle is off, or if SimonK has a brake? Brake isn't usually something wanted on a copter.
@Justin. Thank you for sharing your set up. I would be very grateful if you can share your max power output and thrust if you can determine it.
@Jure, I'm very interested in your X8 Tricopter tilt rotor. Could you post photos for us? Does the rear motor face down and rotate back? Is it similar to this design? http://youtu.be/T6t3EpS3ewU Are you going to use the PX4 code or wait for Arduplane tilt capability?
Comment by Jure M on March 4, 2016 at 8:06am
It's the same configuration, except that I am using these motors for propulsion and these servos for tilting. Unfortunately electronics in servos is not exactly reliable and one of the motors died on me, so I made my own controler...consequently almost all electronics on the plane are my design, ESCs, smart servo controlers, flight controler and also the software - it's kind of a 'can I do it?' project for me :). Will post some photos when I get it all together :).
Comment by iskess on March 6, 2016 at 4:48am
Anyone have a guess on how many degrees I should tilt the motors forward relative to the wing? Should I be looking at the wing's pitch angle just prior to stall, or during cruise to determine the best motor tilt angle?
Tridge, are you planning on angling the whole booms on the wings, or just the motors?
Comment by DBX Drones on March 6, 2016 at 6:36am
@iskess I would tilt the motors enough degrees so that vertical Lift plus vertical Thrust is a reference you give. That depends on TAS and AoA
Another question for the experts like Tridge is how to estimate AoA
Comment by iskess on March 6, 2016 at 12:47pm
I don't understand what you mean by: vertical lift + vertical thrust = reference I give.
Do you mean the difference of the wing lift vector and a line perpendicular to the flat wing bottom? The question is whether this angle should be estimated at min airspeed where the transition occurs.
I'm guessing that this could be estimated by recording the pitch angle at min airspeed in level flight, and comparing that to a bubble level on the ground. It will require a very calm day and some careful flying.
Maybe someone here knows how to estimate the angle mathematically? Or perhaps all wings are so close to being the same, it's not worth the trouble. If so, what is that value? I think a typical angle of incidence is 2 degrees, will that suffice? A typical slow speed AoA is 10 degrees. This seems like far too much to angle the quad motors. I don't want this to cause excess drag in cruise flight.
Over my wing chord, each degree of tilt is about 4mm. My intuition is telling me to go with 3 degrees, but I can't support that.
Comment by Andrew Tridgell on March 6, 2016 at 4:38pm
@Iskess,
for the porter build we didn't do anything special to angle the motors. I am thinking about adding a few degrees angle for the next build (perhaps 3 to 5 degrees?) but have not yet settled on a value.
For our build I think the easiest approach would be to angle the motor mounts a bit with some chocks, but I will have to see how it goes when we put it together.
Cheers, Tridge
Comment by Darius Jack on March 6, 2016 at 5:45pm
@Andrew Tridgell,
I am really sorry, but how could I study your burn out ESC for design flaws, if any ?
Any chance to get ESC type, technical specification, make name ?
Comment
