The wait is over! We are proud to introduce the next generation 3DR autopilot, Pixhawk Mini. Pixhawk Mini is an upgraded Pixhawk designed in collaboration with HobbyKing and optimized to run the Dronecode PX4 firmware stack and QGroundControl multi-platform ground station (Windows, Mac, Linux, Android, iOS).
For just $199, Pixhawk Mini includes autopilot, GPS, and all the cables and connectors needed to get started building DIY quads, planes, rovers, and boats.
What's improved over Pixhawk 1?
  • One third the size--dimensions reduced from 50 mm x 81.5 mm x15.5 mm to 38 mm x 43 mm x 12 mm. Smaller airframes can now operate autonomously without making sacrifices for the Pixhawk footprint.
  • Rev 3 STM32 processor allow for full utilization of 2MB flash memory. Pixhawk Mini operates at only 50% compute capacity, 40 percentage points lower than the original Pixhawk. There is significantly more overhead available to run custom code.
  • Improved sensors, including both primary and secondary IMU (MPU9250 and ICM20608, respectively), lead to much better vibration handling and increased reliability.
  • GPS module included--Neo M8N with quad-constellation support and upgraded HMC5983 compass.
  • Micro JST connectors replace DF-13. We can all breath a sigh of relief.
  • Integrated piezo speaker and safety switch
What's improved over Pixfalcon?
  • Again, improved sensors, including both primary and secondary IMU (MPU9250 and ICM20608 respectively) for much better vibration handling and increased reliability.
  • Dedicated CAN port for UAVCAN applications.
  • Includes 8-channel servo output board for planes and other vehicles requiring powered PWM output.
  • Includes I2C breakout board for a total of 5 I2C connections.
Pixhawk Mini features an advanced processor and sensor technology from ST Microelectronics® and a NuttX real-time operating system, delivering incredible performance, flexibility, and reliability for controlling any autonomous vehicle.
SPECIFICATIONS
  • Main Processor: STM32F427 Rev 3
  • IO Processor: STM32F103
  • Accel/Gyro/Mag: MPU9250
  • Accel/Gyro: ICM20608
  • Barometer: MS5611
  • Dimensions: 38x43x12mm
  • Weight: 15.8g
GPS Module: ublox Neo-M8N GPS/GLONASS receiver; integrated magnetometer HMC5983
  • Dimensions: 37x37x12mm
  • Weight: 22.4g
Interface
  • 1 x UART Serial Port (for GPS)
  • Spektrum DSM/DSM2/DSM-X® Satellite Compatible RC input
  • Futaba S BUS® Compatible RC input
  • PPM Sum Signal RC Input
  • I2C (for digital sensors)
  • CAN (for digital motor control with compatible controllers)
  • ADC (for analog sensors)
  • Micro USB Port
What’s Included?
  • Pixhawk Mini Flight Controller
  • GPS with uBlox M8N module with
    • Concurrent reception of up to 3 GNSS (GPS, Galileo, GLONASS, BeiDou)
    • Industry leading –167 dBm navigation sensitivity
    • Security and integrity protection
    • Supports all satellite augmentation systems
    • Advanced jamming and spoofing detection
    • Product variants to meet performance and cost requirements
    • Backward compatible with NEO‑7 and NEO‑6 families
  • Integrated Power Module (up to 6s batteries) and power distribution board for quadcopters
  • 8-channel servo output board for planes and other vehicles requiring powered PWM output.
  • Cables
    • 4 pin I2C cable and breakout board
    • 6 pin GPS+Compass cable
    • 6 to 6/4 ‘Y’ adapter for additional I2C devices
    • 4 JST to 6 DF13 cable for legacy telemetry radios
    • External safety switch cable
    • RCIN cable for PPM/SBUS input
    • 8 channel RC output cable
    • 6 pin power cable for included Power Distribution Board
OPTIONAL ACCESSORIES
All available here
Comment by Bill Bonney on February 9, 2017 at 5:00pm
PX4 Mini is supported as David is stating on Ardupilot FW beta releases, ArduCopter 3.5-rc1+ & Plane 3.8.0-beta2.
Hope that helps :)
Comment by Arbutus on February 14, 2017 at 6:16pm
Has anyone figured out how to connect the RFdesigns 900+ modems to the Mini?   The pinouts appear incompatible.
Comment by Clay Folk on February 15, 2017 at 5:48am
I second this.  From what I gather, the mini lacks RTS ands CTS pins.
Comment by The Sun on February 15, 2017 at 2:15pm
So are the RFD 900 series modems incompatable?
100KM
Comment by Hein du Plessis on February 15, 2017 at 2:52pm
I never use RTS and CTS on the RDF900s - it can operate without - I'm sure it fully compatible.
Comment by Clay Folk on February 15, 2017 at 2:52pm
I don't know one way or the other.  The mini is sold with a 4-wire cable to connect the 4 pins of the minit to the six wires of a legacy telemetry module.  A module that does have CTS and RTS pins while the mini does not.  So I assume RTS and CTS are not required since they are sold with the idea that a legacy telemetry module will work without them.  It's implied a legacy telemetry will work, though 3DR does not explicitly say it will work.
Comment by Arbutus on February 15, 2017 at 3:17pm
Well then the only way is to try it.  I'll report back.
Comment by Clay Folk on February 15, 2017 at 3:30pm
From what I read, serial communication to a modem is possible without CTS and RTS, but not recommended since it is less reliable.  I was going to try it myself, but I wasn't willing to even try if it's known from the beginning reliability may suffer.
Comment by Bill Bonney on February 20, 2017 at 11:21am
Just wire RTS to CTS on the sending side and you will be good to go. i.e. loop back to trick that hardware flow is available. (though you can disable HW flow control in the parameters)
https://en.wikipedia.org/wiki/Null_modem#Loopback_handshaking
You won't see any issue in transmission reliability, unless the receiving side ie. Pixhawk is somehow becoming swamped with with data. 3-wire serial will work just fine. (and then most of the time it will either tell the sending side to hold off sending, to just drop data bits, it's the same effect in the end, i.e. NO DATA!)
3-wire telemetry will be just fine.
Comment by Jean-Marie PRIGENT on May 27, 2017 at 6:10am
If some people are looking for a 3d printed support for the pixfalcon, I made a 3d support with dampers for the Pixfalcon (v1).
Hope it could help some people: https://www.thingiverse.com/thing:2348176
Comment
