The wait is over! We are proud to introduce the next generation 3DR autopilot, Pixhawk Mini. Pixhawk Mini is an upgraded Pixhawk designed in collaboration with HobbyKing and optimized to run the Dronecode PX4 firmware stack and QGroundControl multi-platform ground station (Windows, Mac, Linux, Android, iOS).
For just $199, Pixhawk Mini includes autopilot, GPS, and all the cables and connectors needed to get started building DIY quads, planes, rovers, and boats.
What's improved over Pixhawk 1?
  • One third the size--dimensions reduced from 50 mm x 81.5 mm x15.5 mm to 38 mm x 43 mm x 12 mm. Smaller airframes can now operate autonomously without making sacrifices for the Pixhawk footprint.
  • Rev 3 STM32 processor allow for full utilization of 2MB flash memory. Pixhawk Mini operates at only 50% compute capacity, 40 percentage points lower than the original Pixhawk. There is significantly more overhead available to run custom code.
  • Improved sensors, including both primary and secondary IMU (MPU9250 and ICM20608, respectively), lead to much better vibration handling and increased reliability.
  • GPS module included--Neo M8N with quad-constellation support and upgraded HMC5983 compass.
  • Micro JST connectors replace DF-13. We can all breath a sigh of relief.
  • Integrated piezo speaker and safety switch
What's improved over Pixfalcon?
  • Again, improved sensors, including both primary and secondary IMU (MPU9250 and ICM20608 respectively) for much better vibration handling and increased reliability.
  • Dedicated CAN port for UAVCAN applications.
  • Includes 8-channel servo output board for planes and other vehicles requiring powered PWM output.
  • Includes I2C breakout board for a total of 5 I2C connections.
Pixhawk Mini features an advanced processor and sensor technology from ST Microelectronics® and a NuttX real-time operating system, delivering incredible performance, flexibility, and reliability for controlling any autonomous vehicle.
SPECIFICATIONS
  • Main Processor: STM32F427 Rev 3
  • IO Processor: STM32F103
  • Accel/Gyro/Mag: MPU9250
  • Accel/Gyro: ICM20608
  • Barometer: MS5611
  • Dimensions: 38x43x12mm
  • Weight: 15.8g
GPS Module: ublox Neo-M8N GPS/GLONASS receiver; integrated magnetometer HMC5983
  • Dimensions: 37x37x12mm
  • Weight: 22.4g
Interface
  • 1 x UART Serial Port (for GPS)
  • Spektrum DSM/DSM2/DSM-X® Satellite Compatible RC input
  • Futaba S BUS® Compatible RC input
  • PPM Sum Signal RC Input
  • I2C (for digital sensors)
  • CAN (for digital motor control with compatible controllers)
  • ADC (for analog sensors)
  • Micro USB Port
What’s Included?
  • Pixhawk Mini Flight Controller
  • GPS with uBlox M8N module with
    • Concurrent reception of up to 3 GNSS (GPS, Galileo, GLONASS, BeiDou)
    • Industry leading –167 dBm navigation sensitivity
    • Security and integrity protection
    • Supports all satellite augmentation systems
    • Advanced jamming and spoofing detection
    • Product variants to meet performance and cost requirements
    • Backward compatible with NEO‑7 and NEO‑6 families
  • Integrated Power Module (up to 6s batteries) and power distribution board for quadcopters
  • 8-channel servo output board for planes and other vehicles requiring powered PWM output.
  • Cables
    • 4 pin I2C cable and breakout board
    • 6 pin GPS+Compass cable
    • 6 to 6/4 ‘Y’ adapter for additional I2C devices
    • 4 JST to 6 DF13 cable for legacy telemetry radios
    • External safety switch cable
    • RCIN cable for PPM/SBUS input
    • 8 channel RC output cable
    • 6 pin power cable for included Power Distribution Board
OPTIONAL ACCESSORIES
All available here
Comment by Marc MERLIN on July 23, 2017 at 11:59am
Wait, I don't need to pass 10 through the little power connector going to the pixhawk's power module plug.
I just need to pass 50-60amps (unlikely that I'd peak at 80, but if so it'd be a very short peak) from the XT60 in to the XT60 out (which I need to solder on the board).
IT does mean that 50-60A would need to go through the power module through the current sensor and back to the other XT60 connector that I'd solder on one of the 4 power out traces.
the problem is that those power out traces are not rated for any known amount of amps.
I can't tell if they top out at 20amp (small quad) or 40 or 60, but I'm dubious that they'll take that much since the trace on the board will have to carry the amps across, and it does not look robust.
I'm not expecting miracles, but I do need a number I know has been tested as safe.
Comment by Arbutus on July 23, 2017 at 1:02pm
The FC only uses a few hundred mA.  The question is whether the power module can safely and continuously handle the peak current that the aircraft requires.
IMHO the Mini 10S power module is good for about 30A or put another way, a 350-450 size aircraft.
Take a look at your motor spec - multiply by the number of motors - add 25% and that is the peak current you can expect.  Now all of that energy passes from batteries to ESCs through the power module. If the PM and its associated wiring and connections cannot handle the peak load, you will discover that at some point in your mission. Also known as an unscheduled hard landing.
Comment by Marc MERLIN on July 23, 2017 at 2:23pm
Thanks, 30A indeed sounds like the most I'd feel comfortable putting through that power module.
As far as how much my motor will use, no worries, I know exactly how much it will be drawing before I take off (through bench testing and a 100A in line current/volt sensor device).
And in this case, it will be a 3.7m glider where the motor will probably peak at 50A-ish (I need to test some props to verify that). The good news is that it glides very well without the motor :) but if the trace on the power module dies, that makes all power to even my ESC could get cut off, including servo control. That would be bad [tm]
I'll use a better power module since I can't trust this one (and before someone asks why I have a pixhawk mini in such a big glider, it's to save on weight)
Comment by Marc MERLIN on July 24, 2017 at 11:47am
Another random question: on pixhawk, if I want to pass receiver RSSI (taranis X8R), I get the RSSI out, put an RC filter, and plug that into the sbus port of the pixhawk and configure
RSSI_PIN: 103
Pixhawk mini does not have that port. Can I use the spektrum port for that, or is there no way to pass in analog RSSI readings to a pixhawk mini?
(with openlrsng I'd be able to pass that on channel 11 as a PWM value, but I'm planning on using an X8R on that model so that I can use smaller antennas hidden in the fuselage)
100KM
Comment by Hein du Plessis on August 15, 2017 at 1:08am
Does anyone know where the ADC port is on the pixhawk mini?
Comment by marcelo siqueira lopes on November 23, 2017 at 5:35pm
Hein du Plessis, do you discovered where are the adc pins out?
Comment by marcelo siqueira lopes on November 23, 2017 at 5:59pm
i need to install a air speed analog what I have  ...
Comment by Thomas Alberts on December 4, 2017 at 9:34am
Is it really true that AC 3.5 works on mini using Mission Planner. I have been having a bear of a time setting one up with PX4 and QGC. I would be more comfortable using MP.
>Comment by Bill Bonney on February 9, 2017 at 5:00pm
>PX4 Mini is supported as David is stating on Ardupilot FW beta releases, ArduCopter 3.5-rc1+ & Plane 3.8.0-beta2.
Comment by Joe Marrone on December 28, 2017 at 2:42pm
I'm new in here, but need some help.  Building a F550 flamewheel hex, and selected the PH mini.  Also want to use companion (Raspberry Pi zero W) for flight control.  Two questions:
1) once I use up the TELEM port for telemetry, how do I communicate with the RPi?  Can I use the micro USB?  What's involved in doing this?
2) The RPiz-w has built in Wi-Fi.  Can this somehow be used to provide communications to the PH mini?
I need all the help I can get so any advice from this group will be helpful.
Thanks,
Joe
Comment by Chris Anderson on December 28, 2017 at 5:43pm
1) Yes, you can use the USB port to communicate with the Pi. In this case, the Pi is the USB host and the PHM is the USB client. Set com speed to 115k.
2) Not easily
Comment
