Quadcopter brushless motor: which brand is most popular one?
Quadcopter brushless motorThere are massive amount of quadcopter brushless motor brands in the market, What factors should you consider when choosing a given quadcopter motor brand? and Which one is the most popular one? Below are listed most brushless motor brands for you.
Cobra
Cobra brushless motors are designed to offer performance and value for your quadcopter. Built from some high-quality components, they provide top-level performance for years. Featuring an integrated motor shaft, they ensure that prop adapters do not spin off during operation.
FPV model
These are high quality and affordable brushless motors widely used for quadcopters as well as other multirotors. Offering both CW and CCW frame options, they integrate high power N42 magnets and CNC machining.
DYS
With a convenient weight, this is a brushless motor brand that offers some of the greatest motors for your quadcopter and other multirotors in the market. With an awesome shaft and exemplary KV rating, perhaps you need to try it out.
Multistar
This is a high-efficiency brushless motor which offers the best spinning power. Given its weight coupled with its awesome shaft and extra long leads, this is a great quadcopter motor.
LD power.
Designed for FPV drones, this high power and high quality quadcopter motor is engineered with high quality magnets and bearings for an outstanding performance. Brushless in nature, they are not only high quality but also come in a pocket-friendly price. With CNC motor cases, they are quadcopter motors worth trying oiut.
EMAX
Given their price coupled with a 3S LIPO battery and a diameter of 23mm, this is a quadcopter motor whose performance is unparalelled. With an awesome shaft of 2mm and an awesome weight, this is a product you can trust.
Sunnysky
Rapidly gaining a reputation in the quadcopter world, this motor is well designed for your quadcopter as well as multirotor. Brushless in nature, they come with prop spinner and mounts for exemplary performance. With an ability to generate a high thrust of up to 2kg, you can trust them with your large quadcopter.
Xnova
Xnova is a brand that has been refreshing its wide range of quadcopter motors day in day out. Providing high performance and a quality which is second to none, you can try these quadcopter motors for impressive results.
Edge
With an impressive 2300KV and an awesome stator length, this is a quadcopter motor worth trying out. At a pocket-friendly price, this is a motor for anyone looking for a quality product without having to dig deeper into their pockets.
Gemfan
To use these high quality quadcopter motors, all you need to do is use the correct propeller sizes since using wrong propeller size could affect their performance. However, they are an amazing quadcopter motor brand worth your cash.
T-motor
Providing an impressive performance and a longer flight time, T-motors are the most ideal motors for your quadcopter if you want your quadcopter to stay in the air for a long time. Designed to ensure the least temperature increase which translates to less heating up, they are quite reliable.
Tornado T1
Tornado T1 motor is simply fascinating. With an aweome magnet which provides an impressive electromagnetic power, you can trust them with your quadcopter. In fact Tornado T1 motors are well built for awesome performance.
Lumenier RX
Designed to give top of the line performance for all your RC models, these quadcopters are not just unique but exemplary. They are engineered from ground up to offer reliable power and enough spinning ability for your quadcopter. Given their strong stainless steel shaft, they are what you need.
Storm
Storm quadcopter motors are designed to offer the best prop spinning for your quadcopter. And yes, designed to conveniently work with props of different sizes, you can always have them for a quadcopter of any size.
RCX
RCX are brushless quadcopter motors which are designed for smaller multirotors and quadcopters. Small yet powerful, they have a capability of running your quadcopter for a considerable amount of time.
Eachine
Eachine quadcopter motors offer an awesome flight time as well as an amazing performance. In fact, their performance is top-notch and have been able to earn a reputation with most quadcopter manufacturers.
Racerstar
Racerstar are the perfect quadcopter motors for your fast moving quadcopter., With an amazing shaft, their KV rating is exemplary. And yes, the price is pocket-friendly. Try them today for a chance to enjoy amazing performance.
Hobbywing
With a long term reputation, hobbywing are quadcopter motors whose track record speaks volunes. Having provided best results for along time, you can trust them as well.
You need to consider below parameters when choosing your quadcopter brushless motor:
1. Voltage.
2. Thrust.
3. Efficiency.
4. Current draw.
5. Response.
6. Props.
7. Vibration.
8. Temperature.
9. Type of magnet.
10. The shaft.
Therefore, What's the best brushless motor for quadcopter? Brushless motors are typically 85–90% efficient or more, higher efficiencies for a brushless electric motor, of up to 96.5%, whereas DC motors with brushgear are typically 75–80% efficient.
Brushless motors are great for several reasons:
  • They have very high power density (in terms of size and weight)
They’re incredibly efficient so they generate very little heat,no wear or contact items (such as brushes) and can spin incredibly fast.
  • It’s very easy to control their speed precisely and adjust it quickly
Power density is incredibly important because on anything that’s flying you want to do everything you can to minimize weight.
  • They’re inexpensive to manufacture
Nobody complains when components are inexpensive.
Comment by DG on June 6, 2017 at 6:25am
Out of the many motors I've used, KDE would be at the top. I have 14 2814XF-515 KDE motors installed on 3 different copters (1 Y6, 2 quads). They are very powerful, versatile, quiet and the triple ABEC-7 bearing configuration makes them stand out from the crowd. 200+ hours between bearing maintenance. Even TM can't come close to that.
No, I don't sell them :)
Comment by EngineerX on June 8, 2017 at 2:47pm
There's has been a huge proliferation of BL motors for multirotor use over the past 2 years. I remember when Sunnysky 2204-2300KV and Cobra 2204(5)-2300KV were so difficult to find. People waited months to get their hands on them. Now, there's so many good choices it's difficult to decide which one to use!
Lots of data on static thrust tests and overview of many multirotor motors, worth checking out
www.miniquadtestbench.com
and of course : https://www.youtube.com/user/EngineerX/videos
Comment by Jack on June 19, 2017 at 7:57am
@John HengLi? Sorry, I rarely hear about it.
Comment
