How do modern open source autopilots compare to aerospace-grade IMUs?
I noticed that Digikey is now selling Honeywell's newest aerospace-grade IMUs, which cost $1,328 each (note that's just for the IMU; it's not a full autopilot). How do the specs of these aerospace IMUs compare to those we use here? Are they worth the extra money?
In terms of overall approach, the Honeywell IMU seem very similar to modern autopilots such as Pixhawk 2.x and 3.3: they both have MEMS sensors with internal environmental isolation and temperature compensation.
As for the sensors themselves, I'm no expert on specs, so I'll just post the basics here, comparing the Honeywell sensor to the Pixhawk 3
On the face of it, the Invensense and ST sensors in the Pixhawk 3 appear at least as good, if not better. But I imagine that there are some other factors that may be more important, such as gyro drift and vibration filtering. The Honeywell specs in drift are shown here:
Meanwhile the Invensense ICM-20602 sensor in the Pixhawk 3 gives its drift in different units: ±4mdps/√Hz. I really don't know how to compare those.
Finally, I'm sure that a lot of the performance depends on the software running on the Pixhawk boards, be it PX4 or APM, both of which use GPS to augment the raw IMU data to compensate for drift, along with a lot of other smart filtering.
So for those IMU experts out there: how do you think these two approaches compare? Are aerospace-grade IMUs worth the extra money?
100KM
Comment by DavidJames on June 27, 2017 at 7:48pm
I logged some data from a Pixhawk 1 and found that the rate noise is close to the the 0.005 deg/sec/root(Hz), single sided level in MPU6000 spec.   A little higher than the spec., but I was bumping the desk at bit when I logged the data and it was connected to noisy USB power.     I'll try to do better next time.  :-)
Here is a link to the flash bin file.
https://cp.sync.com/dl/e7a323cc0#zjzzj4pc-k3r7smth-ek7w2sqi-fj92hh9v
It turns out that the GYR1 data is 1000Hz data but it is scaled in radians per second.
Comment by Anthonie Michael Muller on June 28, 2017 at 7:14am
@DavidJames That's how it's done :) could you do the same test with telemetry connected, servos moving and power from a single lipo? (from my measurements those 2 components generate the most noise)
100KM
Comment by DavidJames on June 28, 2017 at 2:57pm
@Anthonie That is the plan.   I was going to compare the Pixhawk1 with the APM2.6. I may be able to compare the Pixhawk2 on the solo too.    I am actually expecting things to be better on the battery.  USB power is pretty noisy compared to a battery, but you are right all the other stuff will contribute.
I have been trying to master controlling the flash logging process.   Do you know when flash logging is enabled and disabled and when the flash log is written with the fixed wing APM?
Comment by Anthonie Michael Muller on June 29, 2017 at 11:14am
Let me know where I can help, have access to lab psu, ossiloscope, apm2 and apm 1.4 (good for testing, learnt allot trying to diagnose baro drift) maybe PM from here?
100KM
Comment by DavidJames on July 1, 2017 at 3:16pm
I managed to get a 3DR Solo with the Pixhawk 2 logging high data rate gyro data.    The GYR1 data is logged at 1000Hz.   It looks like the Pixhawk 2 has a low noise setup and gets full performance out of the MPU6000.   Here is the MPU6000 root PSD from the Solo data:
So the Pixhawk 2 with the MPU6000 on the separate IMU board gets to the spec 0.005 deg/sec/root(Hz).   Angle Random Walk is then:
0.005 *60/root(2) = 0.212 deg/root(hr), which is nearly 3 times better than the best HG1120.   :-)
Comment by Tom on July 26, 2017 at 8:03am
What is your impression on the signalquest gyro, they are build for rugged applications and im more interessted in their continous vibration rejection. https://signalquest.com/product/rugged-package/sq-gix/
Comment by Tom Jakel on January 27, 2019 at 7:39am
There are so many parameters in IMU calibration that the general drone user may not consider that I'm sure Honeywell does. For instance is the IMU in the Pixhawk calibrated for g sensitive scale factor? That is when the amount of force on the gyro changes the scaling value changes. If anyone has IMU questions or wants to try out a number of high end IMUs or navigation systems let me know
Comment by Andrew Baker on February 8, 2019 at 1:40pm
I am an Engineer for Honeywell located in Phoenix, AZ.  Today they announced their new HG4930 IMU.  It sells for anywhere from $7k to $13.5k.  You can play hockey with it.  Would you play hockey with a Pixhawk2 Cube? :)
HG4930 IMU
Comment by Curt Olson on February 8, 2019 at 2:02pm
Haha, that's awesome!  It turns out you don't need much to get an drone around the sky, but I don't think most people realize how inaccurate their hobby grade systems can be.
Comment by Thomas Butler on February 13, 2019 at 5:30am
"Inaccurate" or lower resolution! Should not confuse accuracy and resolution.  A >$ does not mean better. How much "accuracy" (really meaning resolution) is needed? A cruise missile on track to hit through a bedroom window from a 1,000 mile standoff ( using an IMU in an INS )  is much different from an SUAV taking videos using GPS for position control.
Comment
