I thought people here might be interested in a project that I’ve been working on for a while.
There are no affordable extended duration underwater exploration projects and I’ve developed a hardware platform to provide this capability. The glider uses a mixture of 3D printed components and commodity parts (such as the Blue Robotics tubing/end-caps/serial communication boards).
The model is viewable on the Onshape online platform here (requires webGL)
The glider is fully open source and assembled using parameterisable 3D prints (to adjust parts for your printer to minimise post processing). Instructions are available, with a level of detail that if you're able to assemble a RepRap kit, you should be able to assemble the glider. The only tools required are a 3D printer, soldering station, dremel and then various hand tools such as hacksaw/allen keys etc.
With the Onshape CAD model, you are able to duplicate the model and adapt the hardware for your own requirements (such as adding a front mounted camera) - the glider is designed to be a hardware platform for others to use/adapt, not a project with a fixed use case.
The current software is relatively basic (primarily used to demonstrate the glider ascending/descending underwater), but the control board does have an IMU, allowing for for the addition of a PID algorithm to control glide angle. The control board can also act as a slave board motor controller for the Pixhawk autopilot board and this would integrate with the Mission Planner software in order for the glider to perform autonomous waypoint navigation.
More information can be found on the glider's Hackaday page and any comments/suggestions are more than welcome.
Comment by RM Aviation on October 15, 2017 at 1:37pm
Absolutely brilliant stuff Alex, thanks so much for sharing.
Comment by Laser Developer on October 15, 2017 at 10:34pm
Fabulous!
Comment by Andrew Rabbitt on October 16, 2017 at 10:45pm
Awesome work Alex!  Congratulations
Comment by John Moore on October 17, 2017 at 9:01am
How much endurance are you getting?
Comment by Alex Williams on October 17, 2017 at 9:48am
@John Moore, Currently the glider can operate for about 6 hours (~4km if you extrapolate upon current speed/glider characteristics), however the current glider version has the stepper motors powered constantly and therefore does not benefit from only switching gliding states occasionally. Now that the general hardware is done I will look at optimising power usage and getting a greater endurance (switching gliding states less frequently also increases speed and therefore range).
Comment by Gary McCray on October 17, 2017 at 11:16am
Really great innovation and excellent execution.
A truly novel design, high efficiency propulsion solely by ascending and descending.
Seems to me this might be combined with one of the the wave or solar powered self propulsion boat methods for really long distance or long duration data gathering voyages.
Comment by Antonie Kruger on October 18, 2017 at 5:54am
This is brilliant, great work and thanks for sharing - now I need to get my 3D printer up and going.
Comment by JB on October 18, 2017 at 6:36am
This is fantastic! Thanks for sharing!
Comment by John Arne Birkeland on October 19, 2017 at 12:22pm
Best example of a true open-source/DIY spirited project I have seen in a long time.
Comment by kruk on October 22, 2017 at 7:02am
+1 John Arne Birkeland
Comment
