DroneePLANE- The Professional Mapping & Surveying Drone with API
2 years ago we decided to make a professional mapping &surveying drone and not just for surveyors also with easy API's to help developers/researchers to develop drone applications quickly. And we took 4 main priorities on DroneePLANE:
1.Super easy to operate
2.Safe
3.Easy to carry
4.Affordable
With these main priorities after 2 years DroneePLANE was born. The Professional Mapping and Surveying Drone.
TECHNICAL SPECIFICATIONS
Weight -----------------------------------------. 0.6 kg
Payload capacity------------------------------0.18kg
Wingspan --------------------------------------100cm
  Material ---------------EPP foam,carbon structure
  Propulsion -----------------Electric brushless motor
 Battery -----------------------------10.8 V, 3500 mAh
 Carry case dimensions ----------65 x 50 x 30 cm
SOFTWARE
Flight planning & control software --------- DroneeCockpit
(Ground Control App currently works on Ipad)
FLIGHT CHARACTERISTICS
Maximum flight time---------------------------up to 60min
Optimal Cruise speed-------------------------------12 m/s
Radio link range----------------------------------Up to 5km
Wind resistance--------------------------------up to 12m/s
CAMERA
Dronee supports Sony/GoPro with wifi and all gphoto2 triggering supported cameras including Parrot Seqoioa.
Dronee COCKPIT
Ground Control Software
We designed DroneeCockpit from ground up to empower non-pilots to simulate challenging realistic flight missions through its sophisticated design, and no prior flying experience is required!  You can download  Dronee COCKPIT from App Store and try by yourself.
DroneeCockpit has many advanced features like:
Multi Flight feature: you can scan even larger area with multiple flights.If the battery finishes during the scan.Dronee lands and memorizes where it left in the next flight.
Optimized Flight Plath: For windy weather DroneeCockpit Flight Management Software has “Route Optimisation”  algorithm, it  rearranges waypoint orders to give less drift in windy conditions without changing the result of the process.
DRONEE  API for Developers
Last but not least, DroneePlane is developer friendly. It has built-in companion computer  (RaspberryPi CM3)  with running  Linux operating system and also it has on board GPIO. DroneePlane comes with easy API's to help developers/researchers to develop drone applications airbornready quickly.
For more information check our website : https://dron.ee/pages/droneeplane
You can also contact us for special customization.
Cheers
Comment by Giovanni Esposito on December 4, 2017 at 6:38am
Very good!  Professionally done, way better than the majority of the competitors...serious engineer and designer behind this, no amateurs...  I can't see any big flaws with it, even on the price side, that is what it should be. The only "thing" is that you decided to launch with no Android app.... is it coming soon? From the video looks like what I was searching for.... do you have a beta version to try?
Comment by Tomi Piriyev on December 4, 2017 at 11:11am
Giovanni Esposito
Android version coming soon as well. do you mean android version of app to try?
Comment by Giovanni Esposito on December 4, 2017 at 1:29pm
Yes, I mean do you have a beta version for Android (or Windows) to try? I would like to see the planner/cockpit working...
Comment by Tomi Piriyev on December 6, 2017 at 3:14am
Giovanni Esposito
Unfortunatelly android version of app not available to try, yet
Comment by Pablo Legarreta on December 7, 2017 at 9:15am
Congratulations Tomi!!! I sent you an email.
Comment
