IR Laser Night Vision Zoom Camera For Drone
Sky Eye-12NLT is one 1080P 12X zoom camera designed for multirotors to conduct night vision mission like inspection,surveillance,search and rescue,due to its powerful night vision capability.It consists of one 1080P 12X stellar zoom camera and an IR laser illuminator served as an auxiliary IR light for the zoom camera.The 12X stellar zoom camera features super low illumination:0.0005lux/F1.5(white/black),is able to spot the object as far as 500 meters in the night with the help of IR laser illuminator.
Sky Eye-12NLT offers an wiring hub for wiring and video out(HDMI output),which makes wiring pretty easy and clean.Also the gimbal provides 2 smart speed modes:FAST speed and LOW speed.Fast speed mode is used for small zooming range,which makes the gimbal control sensitive and quick.LOW speed mode is used for large zoom range,will enable you to target the object more accurately.
Sky Eye-12NLT comes with an outstanding advantage that the gimbal can not only be controlled via PWM signal,but also serial command.Also gimbal data(like Yaw/Pitch/Roll angle,zoom status etc) can be obtained by sending serial command to the gimbal via its serial port,which is really useful for precise gimbal control and system integration.
2 useful features are available on Sky Eye-12NLT.The first one is tracking,which will enable the pilot to track object freely during daytime or night time.The second one is geotagging,that means the gimbal will geotag the gimbal position on video streaming or photo that you currently choose on screen,and GPS coordinate will be displayed on the screen too.
So to sum up,in the daytime,Sky Eye-12NLT is a normal zoom camera for drone.And in the nighttime,the gimbal can be used to monitor targets that normal daylight camera can not.
Features:
1) Weight:1265grams
2) 1/1.9 inch 2MP CMOS sensor
3) 12X optical zoom,12X digital zoom,HDMI 1080P/30 video out for video downlink
4) 1080P/30 H.264 video recorded for on-board TF card
5) Super low illumination:0.005lux@F1.5(colorful),0.0005lux@F1. 5(white/black)
6) IR laser illuminator cover range: over 500 meters
7) Auto object track and geotagging
8) PWM control and serial command control
9) Convenient wiring hub for RC receiver and video output(AV and HDMI)
10) 3-aixs high stabilized gimbal system
11) Adjustable control speed: SLOW speed for large zoom range,accurate.FAST speed
for small zoom range,sensitive and quick.
12) One key back to center
Product Link:http://www.yangdaonline.com/sky-eye-12nlt-12x-1080p-ir-laser-night-...
Product Photos
Comment by 孤独的根号三 on March 12, 2018 at 10:44pm
牛逼
Comment
