Tersus UAV PPK solution is coming.
Tersus UAV PPK solution is available on the website now: www.tersus-gnss.com
Tersus UAV PPK solution includes BX316R PPK Receiver, AX3705 Helix Antenna and Tersus GeoPix Software. BX316R PPK Receiver supports multi-constellation and dual-frequencies. It has in-built 4G memory for GNSS observation data recording. Very small and light AX3705 Helix Antenna is designed for UAV applications. Tersus GeoPix integrates the  functions of GNSS observation post processing. Event Mark interpolation and geotagging in EXIF, By clicking one button after input all necessary data, the software will provide the result directly as input for image processing software.
Tersus PPK solution dramatically reduces time and costs. It can significantly reduce GCPs or even eliminate the demands for GCPs. There is no need of RTK correction in this solution, Tersus PPK solution combines forward and backward filter during post processing and it can provide more reliable positioning and higher fixing rate.
Feature of Tersus GeoPix,
1.Simple software interface and simple workflow
2. Automatic processing GNSS data and geotagging images by one button click
3. Shows the result in trajectory plot and the images on online map
4. Provides PPK result in both EXIF and text file
5. The result can be directly used by image processing software,i.e.,Pix4D,Agrisoft,etc.
6.Supports Base station data from CORS or other brands GNSS Receiver,i.e.,RTCM3 and RINEX format.
Item list is shown in below picture:
Tersus PPK Solution is on sales promotion now. USD899 only until October 31st.
Contact me if you have any interests or need any technical supports.
Email: yunxia.hu@tersus-gnss.com
Comment by David on August 21, 2018 at 8:16am
the link is not working
Comment by Haley Hu - on August 21, 2018 at 6:07pm
Comment by ScratchNodado on December 26, 2019 at 7:10am
I inquired thru your website on what tersus product you can recommend to replace our current system...no one answers
Comment
