Hi guys! Recently I had a chance to experiment with Livox Mid-40 - a 230 m range LiDAR using rotational Risley Prisms.
I thought I would share my findings with the community in case it can be considered a viable scanning solution!
The first thing to note about this unit is the weight of 710g that could be a blocker for smaller UAVs. The scanning field of view is 38.4° (circular) and the scanning pattern is as follows:
Visualizing the data here is a raw point cloud of a static scene (decay time - 0s, the gif shows the consecutive scans):
When we preserve each of the scan for 2 seconds we get such results:
My initial idea for using this sensor was for SLAM however due to the scanning pattern I found it difficult to use with off the shelf tools however I think the sensor could work well for UAV laser scanning (assuming a decent positioning system).
If anyone of you based in Europe has a platform that could carry this LiDAR and a positioning system we could use for referencing the scans then I'd be up for some joint integration project.
If you would like to learn more about this LiDAR here is a review that I wrote on my blog. Feel free to let me know if you have any questions and if you have any ideas for some further tests then let me know!
Comment by Darrel Maddy on February 19, 2019 at 4:00pm
Thanks for sharing this. Mine arrived yesterday and I will be trying out a similar static test over the weekend. I will be testing this as a small area mapping platform attached to my DJI S900 frame (emlid edge controller). My plan is to use an intel nuc (i3) on board together with my reach+ GNSS for position (ppk) and the onboard IMU for attitude. It is possible (probable) that a better IMU will be needed but I will see. I have access to tools for georeferencing the point cloud from the moving sensor (postprocerssing) and will see whether I can get everything to work. May take some time :) I will be interested to see how you and anyone else gets on with this (I may need help[)
Comment by Pascal P. on February 19, 2019 at 11:18pm
Amazing price for this lidar ! I am very curious of the final accuracy.
Comment by Mateusz Sadowski on February 19, 2019 at 11:56pm
Darrel it looks like you have a solid plan! Keep me posted as you go! If you run into any issues let me know and I'll try to help. My main business is consulting but I'm happy to do a 20-30 minutes free session with you!
Comment by Vadzim Chareuka on February 20, 2019 at 6:25am
price?
Comment by Mateusz Sadowski on February 20, 2019 at 7:49am
It's about 600$
Comment
