ZOON - 2.4Ghz LoRa Telemetry Module by DRONEE
ZOON is 2.4Ghz LoRa  based long range telemetry module. ZOONv3 can send data up to 21km at 0.5kbps and 6km at 125kbps.
ZOON adds mavlink rssi packets to mavlink enabled data beside LED signal indicators.
Furthermore, "Mavlink NEVER LOST" also dynamically changes data speed and sends only necessary packets such as position,orientation,rtcm(rtk gps),etc. when the drone/robot is far away.
As ZOON uses LoRa chirp spread spectrumIt has strong immunity to reflection from obstacles and other wireless signals around.
Connection to ZOON can be with microUSB, JST - SM04B-GHS-TB, or ST - SM06B-GHS-TB.
It is also full-duplex. (Note also that it has half-duplex physical connection as similar to WiFi).
Learn more dronee.aero/zoon
Comment by Maksim P on May 6, 2019 at 3:04am
Nando te Riele you are right prices are for single unit
Comment by Nikola Rabchevsky on May 8, 2019 at 5:30pm
Are we talking 21km in free air or does that work when you don't have clear line-of-sight?
Comment by juan pablo gayoso on May 9, 2019 at 8:05am
How do you setup with Pixhawk?....i didn't find reference in your site....thank
Comment by Applied Aeronautics on May 11, 2019 at 6:52am
These could be pretty neat to try.
Comment by Maksim P on May 11, 2019 at 10:24am
Nikola Rabchevsky when you have clear line-of-sight
juan pablo gayoso it comes with microUSB(easy connect to PC) and x2 JST UART(4/5pins) connector, if you have ever tried 3DR telemetry module, you will need to do the same here, connect ZOON with JST UART to pixhawk.
Applied Aeronautics feel free to try it, man!
Comment
