The recently released Version 3.2 of my GCS FlightZoomer offers an automatic approach system, that is similar to the ILS for manned aviation. For plane it was working since last year but since copters can't just slip down the glideslope and then touch down with a lot of forward speed, the implemented procedure had to be changed as follows for copter:
❶ At first, Copters will stay in GUIDED mode and will descend on the glideslope towards the runway.
❷ The moment, when an altitude of 7m above ground will be reached, the descend will stop and the copter will continue in level flight until the begin of the runway is reached.
❸ At that point, forward speed will be cut to zero, and FlightZoomer will put the flight controller automatically in LAND mode.
❹ The ArduCopter LAND mode will then simply perform a straight down descend.
As you can see in the examples in the video (towards the end), the whole procedure works nicely and supports rather fast descends.
For what purpose could ILS approaches for copters be useful?
  • As any number of runways and glideslopes can be defined upfront in the FlightZoomer navigation database, the airspace can be structured to support flexible flight operations in changing conditions (different for plane vs copter, have runways for different wind directions).
  • The final descend can start in a controlled manner at a rather high altitude. There is no need to for a long descend in LAND mode.
  • Solution picks up terms and procedures of manned aviation.
More details can be found in the FlightZoomer User documentation:
https://flightzoomer.com/manual/hfw_automatic-landings-_-ils-approa...
Comment by d j on June 2, 2019 at 4:50pm
@ RM Aviation
at what airports,
what type of helicopter,
skid equipped or wheeled one,
what about taxiing time to clear a runway
Comment by RM Aviation on June 2, 2019 at 9:42pm
Not sure of the relevance but:
1. Large ones, small ones and loads inbetween
2. Many types in my logbook
3. Both (see above)
4. What about it? I hover taxi quite a lot, gives the passengers plenty of time to stop screaming.
Please feel free to ask further questions but you will have to state the relevance.
Comment by Harish on June 13, 2019 at 10:53pm
Hi Martin,
I am not much interested in the discussion that whether Helicopters use ILS approach or not.
I would like to applaud your good changes in the Arducopter system that it can land like an aircraft, mostly, if not 100%. But that is OK. I am in your support for this technique.
Still, supporting does not give much outputs. So, when I say, I support you, it is for the technique you have come up with. But I would like to know its practical usage for the mission, its advantages and applications.
Thank you.
Comment by Martin Rüedi on June 14, 2019 at 2:29am
Hi Harish
The usage probably is different for each person. Some might use it just for fun, as the system can give you the sensation of flying a real aircraft under IFR just with your drone, others might like to fly a drone in a way, that seamlessly integrates in full scale operations, others might like to use it as a training system and finally there will be others, who don't need it. It is IFR FPV in a way. It is also "scale" flying (like F4A but with the focus on Scale operations). Another use case could be flying in congested air spaces, where the flight path of drones should be predictable, commandable and adjustable.
Comment by d j on June 14, 2019 at 2:14pm
My dear friends,
since you develop ILS like approach for drones
I am really sorry, being misguided by the subject line in your thread:
"ILS for copter
since you don't develop ILS hardware for copter/drone
I wish you all the best , success and prosperity ;)
Comment by Harish on June 16, 2019 at 12:23am
Hello Martin,
I agree with what you say. I am basically looking for some industrial level applications.
I feel that, in congested air spaces, it will be difficult to have landing approach thing as infrastructures are all high these days everywhere.
Comment
