Stable Power Supply 5V-5A for Raspberry Pi on your Drone
Make your Companion Computer more stable, not suddenly reset by fluctuating power supply in fly time, reduce noise by the devices like ESC, motor, servo…
https://product.xb-uav.com/stable-power-module
Stable Power Module
Stable Power Module is professionally designed with power IC 5V-5A to provide stable power for Companion computer as well as peripheral devices. It also has a built-in Serial port for connecting Companion computer and flight control. All connector in Stable Power Module is Dronecode standard (JST GH and Molex Clik-Mate)
Easy Connect
  Technical detail
Weight:   21gram
Dimensions:   60 x 35 x 15 mm
Power Input:   7 to 36V power input (CLIK MATE 2.00mm)
Power Out:
  5V/5A for
  • Rasp Pi (Jump 2.54mm)
  • Cooling fan, Peripherals (CLIK MATE 2.00mm)
Features:
  • Serial port (JST-GH)
  • Reverse voltage protection
  • Resist fluctuated, noise of electric power
  • Green Led Indicator Power
Compatible:
  • Compatible with all companion computer which have Rasp Pi pinout (2x20 2.54mm)
  • All Raspberry Pi models
Comment by mat on July 2, 2019 at 2:26pm
Nice board, did you try to power a jetson nano ?
Matt
Comment by XBStation 4G UAV Solution on July 2, 2019 at 7:52pm
I haven't tried it yet, but I think it's possible. NVIDIA Jetson Nano J41 Header Pinout is similar to Rasp Pi Pinout(5V - Ground (supply power- Pin 2,4,6) and RX-TX (UART-Pin 8,10)). My PCB is 5A-5V, it's strong and stable for Jetson Nano.
Comment
