mRo Control Zero Autopilot for Unmanned Vehicles
mRo Control Zero Autopilot -- made in USA
The smallest and most powerful autopilot in the world of its kind created for unmanned vehicle builders made in USA!
A high-performance autopilot, specially designed for advanced/professional users who require the best of the best with minimal space.
Built for Builders!
"mRo Control Zero", in its core, is a universal development board and comes fully supported by PX4 and Ardupilot. If you require further customization, the mRo Control Zero will come with all the libraries and examples that will allow you to initialize and access all the board sensors and functions directly via our reference code.
Yes, you will be able to create your custom software for this board in no time, no need to worry about initializing everything (We did it for you). The software is written in C and utilizes a free, easy to install Eclipse-based IDE and supplied by ST. All is included for free with the sole purpose of giving you access to learn, edit, and improve. Be sure to read and understand ST Hardware Abstraction Layer (HAL) license.
But… Be aware of the “limitations” of C, any careless handling of a single byte can potentially provoke a buffer overflow (don’t worry, it won’t damage the board). But hey, This how we all learned at some point, right? The recommended IDE also supports C++ so that you can jump to objects anytime you wish to.
You are Covered!
The mRo Control Zero comes heavily shielded from EMI and highly static hands, so feel free to use your grandma’s polyester sweater while handling the board. Many cloned autopilots come with some potential design flaws that if are manipulated improperly it will permanently damage the board. We know you might have burned one (or two)!
The mRo Control Zero has multiple, independent power supplies, internal voltage sensing, EMI shielding, resettable fuses and buffered PWMs.
The PWM outputs are level shifted to 5V for optimal noise reduction and compatibility across all consumer and commercial ESC devices. With a total of 8 output channels, each with DMA support for 8x dShot devices (yeap, they are all Bi-directional). Every pin exposed is protected.
The PCB is a 6-layer stack with an optimized concentration of copper that ensures excellent heat dissipation, but the F7 and H7 microcontrollers are more power efficient and therefore they dissipate less heat compared to the all F4 microcontrollers.
Lastly, the mRo Control Zero has a conformal coat to protect it from the environment. Conformal coating is an acrylic layer that covers most the electronic “pads” — leaving exposed only the sensors that require direct atmospheric contact, like the pressure sensor and the buzzer.
Click here to continue reading
Where to Buy
Comment by RoboCopter on September 30, 2019 at 11:55pm
Congrats that thing looks awesome! Can we possibly order it without the two plastic connectors?
Thanks,
Chad Amonn
Comment by Pedro Matabuena on October 1, 2019 at 12:35am
Hello Chad, thank you! mRo Control Zero it is really amazing and of course you can order it without the PicoClasp Headers. But first just let me know.
Take a look in the next link at the section called "Connectors and more"
https://mrobotics.io/introducing-the-new-mro-control-zero-autopilot/
Subscribe to the mRo mailing list!
http://eepurl.com/gyoatX
Best,
Pedro
mRo Control Zero in a mixed boat/car
Comment by Roberto Navoni on October 2, 2019 at 12:12am
Great , nice autopilot with some new interesting sensor like new bosh acc/gyro , hope that it working well and the new anti vibration feature solve the tipical problem that we have on this kind of product without dumper, welcome to ardupilot family :)
Comment by Pedro Matabuena on October 2, 2019 at 11:11pm
You need to test it, it is really impressive. Easy to install, very light and powerful. This is a real high-end autopilot!
Comment by EsdTechnik on October 11, 2019 at 7:52pm
Nice!  thank you mRo!
Comment by Pedro Matabuena on October 11, 2019 at 8:22pm
Do you have some of our products? :)
Comment by EsdTechnik on October 12, 2019 at 8:52am
yes. mRo X2.1 Rev 2 :)
Comment by Pedro Matabuena on October 13, 2019 at 11:01pm
Nice! ... The mRo X2.1 Rev 2 Autopilot we used a lot on many wings. But now we have the mRo x2.1-777
Comment by Pedro Matabuena on October 13, 2019 at 11:04pm
mRo x2.1 autopilot in a TBS Caipirinha 2 [mRobotics Inside]
This is a TBS Caipirinha 2 aircraft with mRo avionics inside to perform a general aerial inspections.
Comment by EsdTechnik on October 14, 2019 at 6:05pm
thanks!
Comment
