New Easy Star Accessory - Electronics Chassis
Hello Everyone
The Easy Star Electronics Chassis is being added to the DIY Drones store today. This accessory allows you to mount your APM/Oilpan, GPS Module (Mediatek or uBlox), Differential Pressure Breakout, Receiver, and pan/tilt camera mount on your Easy Star. The chassis provides access to the CLI switch, USB connector, and the Reset button as well as providing a clear view of the ‘ABC’ LED’s on the Oilpan at all times. It is also compatible with two GPS modules; the uBlox module can be mounted to the vertical plate near the back and the Mediatek gps module fits perfectly on the shelf above that (or you could use some double sided tape and stick any module anywhere). Most receivers should fit on the top base and can easily route wires to the APM beneath. The APM is mounted on the bottom and once it is mounted there is no reason to take it out as everything is accessible, but if the need arises, the bottom plate is designed to pop out more easily than the rest of the chassis so there is no need to take it all apart.
The chassis will be sold in two configurations, one with the pan/tilt camera mount (which you might recognize from Jeff’s post earlier in the week) and one without. Hope you like it and happy flying.
http://h9z6z.kmn9z.servertrust.com/Easy_Star_Electronics_Chassis_No...
-Alan
ps. we have flown this with the camera configuration as shown and having the camera off center doesn’t seem to pose a problem. Mounting it this way allows for a less obstructed view, as well as the ability to look down :).
Comment by Peter-Hans de Zwarte on September 3, 2011 at 1:10pm
I tested the resistant and got 1 MΩ < . So I took a chance and put power on the board. Everything worked fine, but this is only about 5V. I guess the result would be something different with some high voltage static shock.
Comment by Sandro Benigno on September 3, 2011 at 2:53pm
Peter, sounds not recommended. Press the foam between the two multimeter probes and you will see lower resistance values. We should expect weird things happening due to vibrations and inertial forces.
Comment by Peter-Hans de Zwarte on September 4, 2011 at 12:53am
I put the foam between the probes, and i could not measure it (1 MΩ <). Even when I measure my body I got less resistance than that.
The pink or green bags are made of low-charging material, i.e. the bag itself will not create harmful charges, but will not protect the item from electric fields.
- Antistatic bag on Wikipedia
Are you guys sure it does conduct?
I got access to a high grade insulation tester at my work, can blast 5000 V trough the material. I will test it there on Monday.
Comment by Sandro Benigno on September 4, 2011 at 1:56am
OK. So, your foam isn't conductive. In fact it isn't antistatic ones.
It's just low-charging (will not create harmful charges by friction... just it).
Here goes a picture of the one I were talking about (the conductive one):
Comment by Peter-Hans de Zwarte on September 4, 2011 at 9:49am
Thanks a lot for your replays, never thought I was going to learn so much about anti-static packaging today :-) .
Comment by Alan Sanchez on September 9, 2011 at 2:39pm
Easy Star Chassis is back in stock today! we are waiting on some materials but we hope to have a Bixler chassis sometime next week :)
Comment by Allan Harley on October 2, 2011 at 1:31am
hi guys is there any news on the bixler chassis yet please
Comment by Shane Hopcroft on October 3, 2011 at 3:46am
An update on the bixler chassis situation would be greatly appreciated. Is it still on the way, or should I just get the EasyStar chassis and try to make it fit?
Comment by Alan Sanchez on October 4, 2011 at 7:45am
Hey guys sorry for the late reply. We have been really busy making quads and getting ready for a CNN interview (today) as well as moving to a bigger place :S . All that should be done this friday, so im hoping sometime early next week for the bixer chassis. Its mostly done, Jeff took it for a few spins and crashes and its looking good. Ill keep you posted.
Comment by Allan Harley on October 5, 2011 at 12:39am
thanks Alan looking forward to it :)
Comment
