2.4ghz: How to read 7 channels with one wire (NOT PPM) with Spektrum modules...
Since i got my new 2.4ghz spektrum radio (I FALL IN LOVE) i always wonder how the daughter receiver send data to the mother, maybe PPM? mmhh not! With a little help of an oscilloscope i started to reverse engineer the protocol used, well i saw only steady digital signal with lows of 8.6 useconds, that responded to the movements of my radio, so i quickly realize that is some kind of serial communication, and i did the calculations (1000000us/8.6us=116279bps) and i thought that maybe the serial speed was 115200bps. So i attached my FTDI cable and start analyzing the data, and i got this:
Spektrum daughter board is sending 16 bytes of information using a serial com. running at 115200bps. As you see in the picture above, the two first bytes are the preamble or sync bytes (0x03, 0x01). The data comes in integers that response precisely in the order is labeled in the picture...
So Paparazzi users this is a way to switch 2.4ghz (only in American), the back of my Specktrum radio says: "NOT FOR USE IN EU", uuh!
I hope somebody can do something usefully with it, enjoy!
Comment by Mark Grennan on December 10, 2010 at 4:22pm
This is just the coolest info ever.  I've been looking for this for a time. Thanks.  I'll try it on my 8 and see what I see.
Comment by Mark Grennan on December 11, 2010 at 1:39pm
My Spektrum DX8 digital receiver has a 3.3v (orange), ground (black) and data (gray) line.  The data seems to be at 115200 baud and is producing a different stream of data.  I have not been able to work out witch bytes are witch controls.
Comment by Øystein Schrøder Elvik on January 12, 2011 at 4:40am
I was finally able to find a way to connect my arduino duemilanove to the spectrum receiver. I was also able to make sens out of the transfer protocol, an wrote a library for pulling the different channels from the signal.
The library and a step by step guide on this topic may be found in this blog post:
http://www.dogfight.no/2011/01/spectrum-receiver-satellite-to-ardui...
Comment by Mark Grennan on January 12, 2011 at 9:26am
I'll duplicate your findings this weekend (if my off systems say quite.)
I have a Arduino Mega to work with.
Comment by Øystein Schrøder Elvik on February 8, 2011 at 4:55am
As mentioned in my plog post you can use the differents in value inteerval to identifying witch channel the bytepair belongs to rather than using syncbytes.
On DX6 the cahannels had each their one interval og 1022 bit. (ch1: 0 - 1022, ch2: 1024 - 2046 ...)
Maby this is a easyer way on the DX8
Comment by Sam Kelly on February 10, 2011 at 3:36pm
Hi guys, in case anyone needs this, here's a sketch I wrote for the Arduino Mega to bind directly with a Spektrum satellite. I didn't do much with the channel data, it just prints the byte values, but there are comments explaining what the different binding modes are.
This sketch was written to work with the DIY Drones Spektrum adapter board (bidirectional 5 to 3.3V level conversion), basically a modified i2c translator board the following connections:
Arduino RX1 <-> SDA <-> sat data line
Arduino TX1 <-> SCL <-> 3.3V reg enable
I don't know when the Spektrum Adapter board will be available or if this will the official configuration, but it worked in my tests and hopefully this info is useful to someone.
http://pastie.org/1550659
Comment by Kenny on February 10, 2011 at 4:27pm
OK, got it working on the micro, and learned a little more in the process. There are two messages. Each one has the same 2 sync bytes, which change every boot, and the first one is not always 0 as thought before. When the radio is shut off (i.e. loss of signal), the satellite blasts out one last message. In that message, during my 20-30 or so observations, the second sync byte increases by 2 or 3. It looks like if it was +2, then it means that the final outage occurred such that it is sending a (partially out of date?) message (1 or 2) where it was meant to be sent, (i.e. Mess#1, Mess#2, Mess#1 order is preserved). If it was a +3, then it is (resending?) a (maybe not out of date, or duplicate?) message such that the final two blasts will be Mess#1, Mess#1 -or- Mess#2, Mess#2.
Presumably some of the FF pads will be overwritten with the higher channel radios. Even at 12 channels, there should still be 4 pads. If you have enough overhead on your micro, and you are running the UART on an interrupt like I am, you shouldn't have to worry about that. Just some sanity checks on the message to see if it's good, while knowing it is in  a known order. My current code is sucking in the pads and then discarding them. I don't really want to sit on a UART and spool taking in useless data. I'll probably work on making it more efficient later.
Mess#1:
02 EE 0B F8 2E AA 13 F0 1C 1B 31 56 FF FF FF FF
sync1 sync2 ail_msb ail_lsb aux1_msb aux1_lsb elev_msb elev_lsb rudd_msb rudd_lsb aux2_msb aux2_lsb pad pad pad pad
Mess#2
02 EE A1 56 01 56 3E AA FF FF FF FF FF FF FF FF
sync1 sync2 gear_msb gear_lsb throt_msb throt_lsb aux3_msb aux3_lsb pad pad pad pad pad pad pad pad
Comment by Kenny on February 10, 2011 at 4:33pm
The below matlab/octave code should get somebody started who want to use the DX8.
% notes about data stream:
% - nominally 32 bytes.
% - sync bytes 00 and ?? (changes every time)
% sync byte pair appears twice in the stream, after each set of FF pads,
% which is essentially part of the sync.
% The FF and 00 pads are constant - always the same length, and in the same
% place, relatively speaking.
fname = 'putty8.log';
fid = fopen(fname);
data = fread(fid,  'uint8');
% counter for packets (channel sets) read
k = 0;
% place in data file
c = 8;
while (c < length(data)-30)
    if (data(c) == 255 && data(c-1) == 255 && data(c-2) == 255 && data(c-3) == 255 && ...
            data(c-4) == 255 && data(c-5) == 255 && data(c-6) == 255 && data(c-7) == 255)
        % packet is starting - this is where a bit mask will go on the
        % embedded system
        c = c + 3; % advance 2 posiitons through the sync bytes, and into the first channel
        k = k + 1;
        ch1_tot(k) = data(c)*256 + data(c+1);
        c = c + 2;
        ch2_tot(k) = data(c)*256 + data(c+1);
        c = c + 2;
        ch3_tot(k) = data(c)*256 + data(c+1);
        c = c + 2;
        ch4_tot(k) = data(c)*256 + data(c+1);
        c = c + 2;
        ch5_tot(k) = data(c)*256 + data(c+1);
        c = c + 8;
        ch6_tot(k) = data(c)*256 + data(c+1);
        c = c + 2;
        ch7_tot(k) = data(c)*256 + data(c+1);
        c = c + 2;
        ch8_tot(k) = data(c)*256 + data(c+1);
    else
        c = c+ 1;
    end
end
% order in radio, order in which they were tested:
% thr ail ele rud ger ax1 ax2
Comment by Kenny on February 10, 2011 at 4:34pm
figure
plot(ch1_tot,'r*-')
hold
plot(ch2_tot,'b*-')
plot(ch3_tot,'k*-')
plot(ch4_tot,'g*-')
plot(ch5_tot,'m*-')
plot(ch6_tot,'y*-')
plot(ch7_tot,'c*-')
plot(ch8_tot,'k--')
legend('Ch1 - Aileron', 'Ch2 - AUX1', 'Ch3 - Elevator', 'Ch4 - Rudder', ...
    'Ch5 - AUX2','Ch6 - Gear', 'Ch7 - Throttle', 'Ch8 - AUX3')
set(gca,'FontSize',20)
grid on
Comment by Mark Grennan on February 11, 2011 at 12:11pm
Does anyone know if the "Orange" satellite receiver (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...) is a drop-in replacement?  I have one on order.
Comment
