Getting 6 Modes out of Channel 5 on a Spektrum DX7s
I know there are instructions for setting up a DX7 and a DX8 to get 6 modes out of channel 5, but the DX7s is a bit different from each of those other transmitters.  Here are screen shots of the 3 sets of changes you need to make to use the 2-way Gear and 3-way Flap switches to send 6 different modes down channel 5.
I hope those are legible, My screen is pretty scratched, and of course for the millionth time I wish the display was backlit.
Comment by Chuck O on March 30, 2013 at 8:02am
The movement of AX1 is not nearly enough. I might suggest that you go back to the settings outlined from Bruce and go to the flight planner radio calibration and see what the pwm values are when changing the Gear 2 position switch and the flaps 3 position switch. Mine were very close to working with his settings only one was borderline.
Comment by Fabian on March 30, 2013 at 11:24am
I restored the suggested settings of Bruce. The result is the following according Mission Planner:
Gear 0: Flap 0 -> CH5 1128 / CH7 1467
             Flap 1 -> CH5 1527 / CH7 1417
             Flap 2 -> CH5 1927 / CH7 1368
Gear 1: Flap 0 -> CH5 1128 / CH7 2086
             Flap 1 -> CH5 1527 / CH7 1807
             Flap 2 -> CH5 1927 / CH7 1569
I did the same but with the Mix1 setting GER->AX1 instead of AX1->GER and Mix2 setting GER->AX1 instead of AX1->GER with the following result:
Gear 0: Flap 0 -> CH5 1376 / CH7 1368
             Flap 1 -> CH5 1775 / CH7 1368
             Flap 2 -> CH5 1775 / CH7 1368
Gear 1: Flap 0 -> CH5   929 / CH7 1807
             Flap 1 -> CH5 1189 / CH7 1807
             Flap 2 -> CH5 1587 / CH7 1807
I don't really understand this behavior.
Comment by Chuck O on March 30, 2013 at 3:12pm
Mine is I am mixed with channel 6
Gear 0: Flap 0 -> CH5 1610/ CH6 1912
             Flap 1 -> CH5 1702 / CH6 1516
             Flap 2 -> CH5 1793 / CH6 1120l
Gear 1: Flap 0 -> CH5 1199 / CH6 1912
             Flap 1 -> CH5 1358 / CH6 1516
             Flap 2 -> CH5 1437 / CH6 1120
Try looking at SETYUP-->SW Select
I have
Trainer:Inh
Flap:Aux1
F Mode:INH
MIX:Inh
Gear:Gear
Knob:Aux2
Comment by Scott Tiller on March 30, 2013 at 11:28pm
Fabian I set my DX7s just as you have and it works a treat. Switch the GER and AUX1 in the mix setup and changed to you numbers. I only really get 5 but all I wanted was RTL, Stab and Loiter, which I now have thx to you and Bruce. Cheers guys.
Comment by Fabian on March 31, 2013 at 2:34am
Chuck, your CH5 values look nice. That's what I want to get too. I have checked the SW Select which are the same as your's. The problem is that I don't really understand the concept of Servo Setup and Mixing in detail. Unfortunately the manual of the DX7s is no help.
I'm still helpless on that topic. Would be nice if you could help me finding the problem.
@Scott: Nice to hear you are happy with the settings I posted. If you could manage to get 6 modes I would be very interested on how you managed to get these.
Comment by Fabian on March 31, 2013 at 3:51am
After a lot of try and error I managed to get 6 flight modes out of my DX7s with the following settings:
Servo Setup -> Gear                              Servo Setup -> Aux1
Mixing -> Mix1                                       Mixing -> Mix2
Hope this will help some of you.
Comment by RPF on April 5, 2013 at 9:54pm
@Fabian -- I've replicated your settings on my DX7s, but it's not working quite right.
Before changing anything, the flap switch would flip between flight modes 1, 3 & 6.
After the changes, the flap switch goes between modes 4, 5 & 6.  The Gear switch doesn't really have any affect.  If I flip the gear switch to #1, I can only switch between flight modes 5 & 6 using the flap switch.  I'm never able to access flight modes 1, 2 & 3.
All the offset values are a bit confusing and I haven't seen any information indicating as to why when I change the vales to 90%, 32% and -90%, the toggle switch will act as an alternating toggle.
Any advise?
Comment by Mitch on April 22, 2013 at 5:38pm
Actually what would be SUPER helpful is for someone who has this working to upload the configuration file. So if you could save the working model to the SD card, then upload that file to the source code server. Then we could download it ourselves and copy it our SD cards and insert that into our DX7s and we should be all set.
If its too hard to get permission to post the file on the server, I would appreciate it greatly if someone could email it to me directly at mcorriel@yahoo.com Many thanks in advance.
Comment by Brian P Gibler on June 10, 2013 at 6:08pm
Hey guys sounds like a lot of trial and error has anyone got a fool proof way to get 5 or 6 flight modes? I tried the settings first given in this blog and nothing seems to be changing in mission planner when I calibrate or set up flight modes, what am I not seeing. thanks for any help.
Comment by Serpentaire on July 29, 2013 at 8:20am
Bruce or Fabian.....
I'm trying to replicate the settings on the screen but I noticed on both of your posts that under Servo - Travel - Gear there are two percentage numbers.
Bruce - your original pics show 40% (left) & 70%(right) but when I go into these settings I can only adjust the number on the right.  How do I adjust the one on the left.  I have pressed every button on the controller but still cannot get it to move to that % value on the left.
Any suggestions?
Comment
