3D printed tricopter - from CAD to reality!
3689547029?profile=original
I'm Adrian from Hungary/Europe. Let me introduce my tricopter project.
My goal was to make something really good-looking copter that have ally features I need.The design process started 1 years ago. My first idea was to make a composite chasis, from glass/carbon fiber.I designed the copter in a 3D modelling software, and also designed the necessary moulds for making each parts, here is the initial design:
3689546905?profile=original
This is a sample of the mould design:
3689547050?profile=originalI also made some FEM calculations, to check the stress dispersion:
3689546928?profile=original
3689547001?profile=originalUnfortunatelly, this type of production would cost too much for me. I tried to find partners in Hungary, without success. So I almost forgot this project. But some months before I read a lot about 3D printing, and finally I found a great partner in Hungary (many thanks to the Ground Zero Team www.groundzero.hu !!!). So I started to redesign my copter according to the requirements of 3D printing:
3689546950?profile=original
3689547165?profile=original
3689547114?profile=original
Then I sent the .stl files for FDM printing. Here is the result:
3689547192?profile=original
3689547127?profile=original
3689547206?profile=original
This is my current configuration:
  • Turnigy SK3-2826-1130 motors
  • 8x4,5 karbon SF props
  • 10A HK ESC (simonK firmware)
  • ArduFlyer 2.5 with ArduCopter 3.0.1 code
  • ULOX NEO6-M GPS
  • 2000mA 3S lipo (2 db 1000mA 3S2P)
  • Flytron 25A ultralight current sensor
  • MKS-DS95 servo
  • RECOM 5V 1A power supply for electronics
  • 3DR 868 MHz telemetry module
  • RCTimer OLED screen
  • Immersion 600mW 5.8 video TX + Coverleaf antenna
  • MinimOSD, with KVTeam code
  • KPC-E700PUB camera
  • FRSKY Futaba FASST-compatible receiver, PPM
  • controlled LED-s and buzzer
All-up weight is 782g, and has 8 minutes of safe flight time with 20-25% of remaining battery.
(Please note that I used Crius AIO Pro at first with MWI code and KV-OSD code. These can be found on the following pictures and in the videos.)
3689547227?profile=original
3689547081?profile=original
3689547253?profile=original
3689547247?profile=original
3689547268?profile=original
LED sripes are controlled by APM:
3689547311?profile=original
3689547354?profile=original
Here are some videos:
Flight test (with Multiwii)
Onboard video (with Multiwii + KV-OSD)
3689547322?profile=original
3689547281?profile=original
For more details please connect me by mail: nhadrian@gmail.com
- UPDATE -
stl files can be downloaded from here:
http://shpws.me/oGJN
http://shpws.me/oGKc
http://shpws.me/oGKd
http://shpws.me/oGKg
http://shpws.me/oGK7
And these are the additional metal parts for rear arm control:
3689547406?profile=original3689547380?profile=original
I wish you all good luck on reproducing my tri.
Please note that I'll not modify desing according to personal wishes, since my spare time is quite limited and I focus on my personal projects. Thanks for understanding!!!
Best Regards
Adrian
  • Sorry for confusion !
    I didn't noticed that Adrian shared a quad version also.
    I was so excited about this project that I missed the comments...
  • @Catalin, I did not design this 3D data, so please ask originator.
  • Very nice project !!!
  • My friend printed out Quad copter by "3D Touch 3D printer"
    It needs sanding and filling for better fitting and strength.
    3692844469?profile=original
  • 3692836613?profile=original
    Printed standing up with ABS on a Rostock Max. Strengthened with a thin layer of fiberglass&epoxy.
  • Any news there?
    I'm waiting for my new 950 KV motors and 10x3.3 V2 T-motor props!
    I hope flight time will be over 10 minutes.
    I told you that probably it is impossible to print frame without support material.
    I really recomment printing on a stratasys printer. I saw them working, and the part is really-really accurate since if it is neccessary, it uses support material even for big flat walls.
    For example, this one: http://www.stratasys.com/3d-printers/idea-series/uprint-se-plus
    Good luck!!!
    BR
    Adrian
  • Think I go a problem...the shelf is not printing very good.
    3692829971?profile=original
  • Here is the progress so far...
    3692829909?profile=original
  • Wow...7 hours to print ot part 1 of quad. It's not finished yet but it looks good so far. Thanks for all the help. I like quad's more than tri's.
    Earl
