3D Robotics ArduCopter now available in complete kit with motors/ESCs/props
The cool black 3DR ArduCopter kit is now available with motors/ESCs and props included for $295. Or get it with full APM autopilot electronics (including GPS and magnetometer) for $590.
Comment by Dara Shayda on October 7, 2011 at 3:28pm
I have some impressive bit of data from people who actually tested the copters, these pretty significant performances, actually was taken back by surprise :
"Every aircraft have its ceiling altitude, but we don't have that exact number. I've tested the quad with a Go Pro camera on board, at 200 mts. aprox. you can barely see it, it's almost a dot in the blue sky. The good thing is that you will be able to push it in alttiude hold mode, and then control the altitude of the quad with the stick, but also, watching on your computer screen the location  and actual altitude, so you can test how high you still have control on it. And also, wind gusts have more speed at high altitudes.
I like to use a 3.3 A-hr Lipo battery from HobbyKing, this one gives me 8 to 12 mins, of aggresive, high altitude flying, and almost the 15 of not-to-much-throttle flying. But you can use a bigger battery, like a 4.0 or even 5.0 A-hr, A little heavier but you can get up to 18-20 mins of flight time."
Comment by Björn Geir Leifsson on October 8, 2011 at 12:26am
Any plans for a hexa version?
Comment by Hai Tran on October 8, 2011 at 2:19am
What material is this new frame made out of?  I'm assuming the arms are aluminium? what about the landing gear, and main plates?
Comment by Michael Pursifull on October 8, 2011 at 3:13am
All details from my own frame/imagination, correct me if I am wrong.
Arms are 20mm square tubes of black powder coated aluminum, ~1mm thick
Plates and landing gear are ~1.5mm thick carbon fiber, no fancy weave, just strong and light
The fittings are either nylon spacers, nylon screws, metal screws, or metal nuts. There are some nylon washers but I did not use them. The landing gear, for example, are two plates CF, separated by nylon spacers, and fitted with metal screws (to one another, w/spacer) and to the frame with metal screws and metal nuts.
You can remove one screw each of two of the arms, and fold up the frame if you have mounted the ESCs on the arms, and left enough space for the wires, but I suspect if you mount the ESCs in the middle between the arms, you may not be able to do this.
I've been thinking of adding some type of rubber feet to the bottom of the landing gear, but haven't done so yet.
It is a very solid/stiff frame. You could probably beat someone with it, and maybe the most that would happen to it is to break the nylon standoffs that support the central stack.
Comment by oejang aja on October 8, 2011 at 5:34pm
Great, finally :)
chris.. is it tested or just assembled version  ?
Comment by Chris Anderson on October 8, 2011 at 8:56pm
oejang: I don't understand the question. Can you rephrase?
Comment by Michael Pursifull on October 8, 2011 at 9:32pm
My impression is that this is a kit, delivered in parts, not pre-assembled, so also not tested.
From the description, I would expect the APM/IMU will need to have pins soldered, the PDB will also need to be soldered, the frame needs to be assembled, the motors and ESC bullet connectors/cables need to be soldered, magnetometer needs to be soldered, ArduCopter code needs to be loaded for the first time, components assembled and you might need more parts ... more zip ties or other fittings for attaching electronics to the frame, and some foam or other isolation for the APM, and foam to cover the baro. The props need to be balanced, and the needs to be balanced to its center of gravity.
The jDrones kit that costs about the same is also not assembled. You can buy a jDrones fully assembled and tested, for about $250 more than the kit. At the moment, I do not know if anyone is selling an assembled/tested 3DR quad.
But I do not have this kit, so that is based entirely on the description on the Webpage.
Comment by Ivan on October 9, 2011 at 11:13am
Hi
Are there specs on this somewhere?  I have looked but perhaps I missed something obvious.
Looking for sizes mainly, length of each arm, length across.
Comment by oejang aja on October 11, 2011 at 12:02am
@chris : sorry for my english... I mean, is it complete kit or "fly tested" version (RTF) like Jdrones offer  ?
I think mike already answer my question :)
Comment
