9x radio 'mod' list
3689450924?profile=original
That my list of 9x radio mods, Keeping it DIY, and under $200 :)
First one is 'er9x' firmware super easy:
Here is wiki page and good 'How to wire' videos: Part 1 Part 2 Part 3 you'll need some programmer this one works fine
also you can use arduino board
'eepe' tool is here
Next one is the 6 position 'mode' switch for ArduPlane/Copter, here is my original mod and complete 'how to' from Paul. That is 2 pole switch, so its 2 switches in one and I used that second switch for LEDs.
Next is the Turnigy 9X LCD Backlight Kit from HK 'how to' is here :)9X-LCD-BL.jpg?width=600IMPORTANT !!! DON'T DO THAT
Step3(2).jpg?width=600
Just cut-off some of extra foam but don't try to completely remove it, big mess !
Speaker Mod with Haptic Feedback really cool one :)
Next FrSky Telemetry
3689450950?profile=original
There is number of ways to do it 'How to modify your 9x to support telemetry'
one is using 'FrSkyLite' that also used for 'FrSky' firmware upgrades.
But here is another one that also converts 'FrSky' module to support firmware upgrades via FTDI cable.
3689450847?profile=original
You'll need to perform minor surgery on that DHT DIY module :)
3689450981?profile=original
And some work on the 9x board too.
3689450650?profile=original
But the most important part is the new ERSKY9x ARM board for 9x radios !!!
file.php?id=301&t=1&width=600
Here is a Feature List:
input voltage 6.5 - 16 volts (7.2V ideal)
Atmel SAM3S ARM Cortex M3 Microprocessor
256K of Eprom , 48K Ram
4mb EEprom - For Model /sound storage
Support for Optrex display F-55472GNFJ-SLW-AAN
Built-in external USB socket for Programming / interface.
2 external RS232 Serial Ports.
PWM control of LED backlight . (dimmable)
1/2 Watt Mono Audio Amp , with digital volume control
8 ohm speaker output with auto switch over headphone jack output.
Micro SD card socket with 4 bit high speed connection to ARM
Support for RN-42 Bluetooth Module (spot for external TTL serial connection)
Haptic output connector , with PWM drive.
ATTiny167 AVR micro for RTC and 12 external switch inputs/encoders or up to 10 A/D inputs , can be battery backuped
External I/O connector with 4 lines one with DAC output
I2C output connector + spare port pin.
5V output.
On board current sensor , to measure power usage on battery
Second PPM OUTPUT
Software control of Power - off
Should be out soon for $85 !
    @Kamu, not yet.. :(
    but here some good news http://www.ersky9x.net/Products.html
  • Hey Max, did you ever get around to doing that thumbstick mod write up?
  • hi fellas, is it true the smartiepants board er9x is just a interface board to allow to upgrade the firware on the 9x radio stock board and once done you can only store 1 model due to the memory size?
  • That PSP thumbstick is an awesome idea. Waiting for that tutorial! :)
  • the two upper pots.
    You can route two of any of the three pots avaiable, i think there's no difference.
    Small joystick from sparkfun is cool and small, but i could not sort how to cable it to the 9x, although i'm no master in electronics.
    With my joystick, which is one clone nunchuck for the Wii you can find cheap on eBay, you have the standard 3 wires for each pot. You must cable the two outer wires in series with the original pot, while cabling the center wire on the switch (which is a "diverter" type, double pin strip - i hope it's correct in English) which routes the middle wire from the one from one pot or the joystick one. Repeat the same for the other pot.
  • What pots did you reroute the cabling from?
  • It recenters. if you look carefully,  there's a switch next to the upper pot. With that,  you choose to use the two pots to move cam axis in a "fixed" no-recentering way or move with the joystick with recentering. You must do zero position with subtrim menu.
    That's mandatory because if you connect both pot and joystick, it can work (pot acts like trim) but if you reach end positio  with pot and joystick,  it causes radio to reboot due to an internal short.
    @max: very nice!
    @Mago, haha, that was my next mod on the list !!! but using this joystick:
    3692386447?profile=original
    3692386380?profile=original
    @Paul, I'll post the how to for the LEDs as I done with the joystick thing :)
  • Does it recenter the camera when you let go of the sticks or stays that direction until you move the joysticks.
  • here's a "teaser" of it.. ;)3692385521?profile=original
