New product! The 3DR Radio Telemetry System
Hi everyone, I'm very happy to announce something that 3D Robotics has been working on since late last year in cooperation with a few very talented developers. Today we are announcing the 3DR Radio telemetry system, an open-source alternative to XBee telemetry set-ups, with superior performance, great range and a much lower price (half the price of the equivalent Xbee kit).
This is a 2-way, half-duplex wireless communication system with a standard TTL UART interface, based on HopeRF's HM-TRP data link modules, and custom firmware that improves upon the module's original features and performance.
The SiK firmware includes a bootloader that permits radio firmware updates over the serial interface, and radio firmware with configurable parameters. Updates and configuration are fully supported in the APM Mission Planner (press control-A to bring up the window below), and also possible through AT commands.
From the wiki:
  • light weight (under 4 grams without antenna)
  • available in 900MHz or 433MHz variants
  • receiver sensitivity to -121 dBm
  • transmit power up to 20dBm (100mW)
  • transparent serial link
  • air data rates up to 250kbps
  • MAVLink protocol framing and status reporting
  • frequency hopping spread spectrum (FHSS)
  • adaptive time division multiplexing (TDM)
  • support for LBT and AFA
  • configurable duty cycle
  • builtin error correcting code (can correct up to 25% data bit errors)
  • demonstrated range of several kilometres with a small omni antenna
  • can be used with a bi-directional amplifier for even more range
  • open source firmware
  • AT commands for radio configuration
  • RT commands for remote radio configuration
  • adaptive flow control when used with APM
  • based on HM-TRP radio modules, with Si1000 8051 micro-controller and Si4432 radio module
Support for different countries and regions is documented in the wiki:
Of course, the list will keep growing, and you can help by providing links on the forums to relevant information on the applicable regulations. This is a DIY radio device, so please check your local rules carefully!
Each kit consists of an 'air' and 'ground' variant, with an FTDI-style 6-pin header and USB type-A connector, respectively. Also included are two RP-SMA antennas, APM telemetry cable, and a USB type-A extension cable for placement flexibility.
Kit price is $74.99:
Individual radios are $35.99 (USB) and $31.99 (pins):
Kits and radios are available for purchase today, and they will start shipping next week.
Coming soon: a 3DR Radio XBee footprint adapter for both frequencies, compatible with our USB XBee adapter and Sparkfun's XBee Explorer boards.
We will also be releasing a version of the radios on both frequencies with an Xbee-compatible footprint, so you already have Xbee adapters, you can use them.
We hope you enjoy using these radios as much as we have during development, the simpler hardware and configuration tools compared to XBee provide a much smoother experience. We look forward to hearing your comments!
Huge thanks to the developers who made this happen: Team leaders Andrew Tridgell and Mike Smith along with Michael Oborne, Seppo Saario, Marco Robustini and others.
Comment by Jota Parro on December 3, 2013 at 4:28am
Thanks! if I undertand properly, I must change the wire from the groun unit to remote, conect and update.
Comment by Brad Roekle on May 26, 2014 at 9:30am
Does anyone know if I can use this board : http://www.wvshare.com/product/FT245-USB-FIFO-Board-type-A.htm to update the firmware on my air 3dr module.
Comment
