This application was designed to help you test your ArduIMU V2 by showing graphically and numerically all of the data being output from the IMU.
You can download the Setup here: ArduIMUTest Setup (3 MB)
This version of the Test App uses the MSCOMM control, so the max COM port number is 16 (unfortunately a limitation set forth my Microsoft).
Before starting the application, make sure your ArduIMU is sitting flat with the serial cable towards yourself. When the application starts, it will automatically try to find the right COM port and it defaults to 38,400 baud.
To reset the ArduIMU, click Disconnect and Connect again on the application. It takes about 10 seconds for the ArduIMU to boot up and start sending serial messages so please be patient.
No need for LabView runtime! Yay! However, it now requires DirectX 8 runtime :)
EDIT: A special thanks to Michal for providing the 3DS file and texture map! Thank you Michal!!!
Comment by Varinder Gill on May 27, 2012 at 3:40am
try and reloading the code again
Comment
