Black X8 EPO wing
Hi All
The Big Black X8 Wing is now in stock at FPVflying.com
3689459653?profile=original
3689459595?profile=originalWing span : 2122mm
Wing area : 80dm2
Valid payload : 1000-2000g
Requires for flying :
Folderable prop 12 * 6 or 12 * 8;
2 * 20g servos(the size of  servo hole on the plane is 40*40mm);
60A ESC or bigger;
4s 6000---10000mah lipo
More info: X8 Wing for UAV flying
  • It's rated to take up to 2kg payload...anyone with one think it might carry 3kg with a bigger esc & motor and keeping it gentle and fast in flight??
  • Hooks, or anyone else, do you have an APM parameter file for the X8 yet?
    Don't know what happened to the link. It's now corrected.
  • Correct Link
    HERE
    @arashi, thanks for the update!
  • i like it a lot.. probably a low radar cross-section, if you could find iron ball paint, you might get a stealth drone of your own :)
    3692433537?profile=original
    Of cause wings are detachable. who got a car that can handle a 2.2M flying wing...
  • And four screws for the winglets
  • The wings are removable. The attachment uses two carbon fiber tubes and a plywood plate. Only two screws are used to fix the wings.
  • Ive been reading the RCG thread and it looks a like a few people have used plywood plates and a mounting screw to make the wings detachable.
