Bridge 3dr telemetry/Bluetooth and ArduStation3
This is my last test to use bridge bluetooth + 3dr Telemetry 433Mhz  on Ardustation3, works very well in same time, or only bridge and/or ardustation alone :)
https://code.google.com/p/ardustation3/    Jesse's ardustation 3 - Graphical LCD
Comment by Rana on December 8, 2013 at 4:02am
Hi ! is the link you have provided, is the same part you have purchased and using for this project ?
Comment by Rana on December 8, 2013 at 4:05am
Hi F5PQL !
Requested, to pls share the complete schematic / wiring detail and assembly instruction of Ardustation 3
Comment by F5PQL on December 8, 2013 at 4:30am
Comment by Peter Seddon on December 30, 2013 at 9:59am
I would like to compile the Ardustation3 code but am lost as there seems to be VisualMicro files in the repository. Please could someone give me a steer - I am using the Arduino IDE.
Peter
Distributor
Comment by RC Tech.se on January 7, 2014 at 3:59am
You have to move all the stuff from Ardustation3 "libraries" to your local "libraries" (usually in your Arduino folder in Documents)
Comment by Rana on January 13, 2014 at 8:13pm
Hi F5PQL ! mine came and the code is running fine in the module. Now I need wiring diagram or something like that which may help.
cheers !
Rana
Comment by Rana on March 18, 2014 at 11:59am
If queries remains open for months then what is the use of your starting this blog ?
Comment by Frenchguy on March 18, 2014 at 12:04pm
People post and forget. It's easy to get motivated to do one write up after a project completion but hard to actually slow down and help other.
Comment
