This week I started building my MTP or Modular Test Platform that will help me someday build a full/partial UAV that will cross all 3,000 miles of the U.S.*
I constructed the modular tail section that will be able to separate from the fuselage, nestled the servos in really good to reduce drag, and placed the control horns as closely to the pivot point to increase control surface range.
I tested my electronics: I took the Servo's, Tx and Rx from a crashed Wild Hawk RTF, and new 2200 mAh 20c batteries, 1,400 kv motor, 30amp Mystery ESC, and a 8x4 apc prop (all from Hobby King) and hooked it all up, then powered them up to see if all was well. And it wasn't!
My ESC/Motor set up was non-functional. I'm not sure which or if both are not functioning, and as this is my first brushless set up, I don't have other electronics to test it with. I checked all the connections to make sure everything was set up correctly, and made other efforts, but couldn't get them to function. I went ahead and ordered new parts to replace both, just in case, while I complete the airplane construction to stay on schedule.
I plan on completing it next week, maybe even making the maiden!
To see what I I did, check out the episode on YouTube above
*visit www.MyGeekShow.com for the full details of my 3,000 mile flight goal
Maybe a mod would fix
it?
Brent: that's not correct
brushless and brushed ESCs with only one direction look for 1.0ms
brushless and brushed ESCs with reverse capability look for 1.3-1.5ms
doesn't matter which TX you have, they will send the same values
Russell:
I took a look on HobbyKing at a Turnigy 9x, they look pretty good, and have good reviews, do you have any experience with them?
Brent:
I've never heard of that, but it wouldn't surprise me, especially since the Tx is so cheap. Sad day... I may have to try the set up on a friend's Tx Rx that is higher quality. I'll let you know what I find out.
Time to get a Turnigy 9x. LOL
