I completed the MTP II (Modular Testing Platform) as far as I could while I waited to receive the new Motor and Servos I'd ordered. They came in the last day of this week, so I'll be completing the MTP II next week. There is a lot of improvements on this design/construction over the first MTP, some include:
-Minor fuselage improvements for better aerodynamics and strength. (including moving the wooden dowels to be apart of the construction instead of just sitting inside the fuselage.
-Improved airfoil: I got a lot of feedback that while the K2 airfoil was functional, I'd be better off with a more classic airfoil, so I built a Clark Y airfoil. I got the information for this wing from: http://www.worldofkrauss.com/foils which is an AMAZING site for airfoil research. You HAVE to go check it out. I gives not only the exact shape of each airfoil, but also it's flight characteristics. Very cool.
-Next, instead of using one of my radio's channel to control the rudder, I'm using it to control a set of ailerons, which will give me a lot more control and allow me additional roll stability options. I stole this idea from fellow YouTube user PeteDaws.
-I also used CA Foam Safe Glue instead of Hot Glue. In the past I'd had airplane literally melt in the trunk of my car due to all the heat, CA Glue won't fail due to that as once it's bonded, it doesn't let go. Also I found that the construction of the airplane was much more precise and clean. Weight also dropped by about 15 - 20%.
-Lastly, I ordered a larger motor as the last motor was too weak for this size of airplane.
So what do you think? Looking better? Any other improvements I should make before I make the maiden?
Links:
New Motor: http://www.hobbypartz.com/75m55-optima450-2220-1800kv-2.html
Old Motor: http://www.hobbyking.com/hobbyking/store/__2107__Turnigy_28-22-azj_7A_1400Kv_Brushless_Outrunner.html
CA Glue I Used: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKAV8&P=ML
Wing Design Site: http://www.worldofkrauss.com/foils
PeteDaws video I got the aileron idea from: https://www.youtube.com/watch?v=9WSVLErw-dQ
  • With your age and such great skill sets, It seems that you have been brought up in the aeromodeling environment only ! BTW nice concept and nice approach !
  • If You wanna try different wings You might need a rudder.  your first wing has no alerions
    I like it and can feel this one will fly.
  • Note that the Clark-Y airfoil will have about 3 degrees incidence with the bottom of the wing sitting flat on top of your current fuselage. This is one of the benefits of a Clark-Y for simple airframe construction.
    A good start ;-)
  • Gary: Yessir! I'll add that too. Good call. 3 degrees would you say?
    One phrase this time Trent, Angle of Incidence.
