CNC Machine 6040 for 650€
3689738026?profile=original
Ever wondered how to cut wood, plastic, thin carbon fiber pieces in order to make you drone frame, the ribs for your fixed wing plane or whatever you are trying to fabricate?
Check this new CNC out: https://sandwichdrones.it/collections/porcodio/products/cnc-machine-6040
Contact me if you want the kit with 3D printer plans at nicolai.valenti@gmail.com
  • Every RC aircraft designer needs such a machine. Thanks for posting the link.
    If he could make a machine one of his own it would be fantastic. I bought a kit from ooznest of UK. It cost me euro 1000. I fitted it with a Makita router which was euro 110.
  • Hello Robert, this design is similar but not the same.
    My design has a much more cutting surface, and completely different aluminum profiles holders. I already tried the design you linked and had many troubles because the printed parts, especially the corners are very easy to break during the assembling and does not fit the 2020 aluminum profiles.
  • For those with a 3d printer, the parts for this design is available on https://www.thingiverse.com/thing:3004773
    DIY Dremel CNC design and parts by NikodemBartnik
    Support my projects on Patreon: https://www.patreon.com/nikodembartnik DIY CNC machine is a very popular project on the internet, a lot of people mad…
