Today everybody and their dog seem to be working on a quad project. And with my own quad having reached a relatively mature stage with stable flight some time ago, I thought it would be nice to try something different.
So inspired by the full-size Osprey tilt rotor design I just started an experimental duo/tilt copter build. Frankly I am far from sure if it will ever fly, but that is what makes it fun!
Mechanical:
My tilt design is one I used in an earlier tri-copter build. I insert a 8mm CF rods into a 750x10,5mm CF square tube and glued then together. A modified T-Rex 600 blade-holder is then inserted on the 8mm tube and fastened using glue. Finally a servo is epoxied at the side of the square tube and linked to the 600 blade-holder. Motor and ESC is a cheap TowerPro combo from HobbyKing. Cheap and easy to replace when experimenting, and the ESC has no problem handling 333mhz PWM pulses.
45 members
1472 members
282 members
470 members
57 members
Powered by
