3689568730?profile=original
We have developed a version of the SurVoyeur mk-II, the 'c' version, which has a new nose housing a gimballed, stablized EO and IR camera combination.
This gimbal houses the FLIR QUARK 640 X 512 pixel Thermal camera, fitted with a shutter to enable flat field correction,  and also houses the Sony EX11 Colour Block Camera.
Both camera are fully controllable from the ground station, colour modes, zoom where applicable, AGC, etc.
The gimbal is stabilized and fully steerable from the ground station. We are currently working on making accurate fitment jigs to bore-sight the cameras to the IMU, to enable accurate line of sight determination to allow automatic tracking of designated 'targets'.
Here are some photos of the various parts of the Gimbal, and the Gimbal fitted to the aircraft.
The two cameras with the QUARK shutter mechanism:                                   The assembled Gimbal:
3689568679?profile=original
3689568343?profile=original
Pre-assembly:
3689568758?profile=original
3689568751?profile=original
3689568775?profile=original
3689568864?profile=original
A short video of the gimbal in motion:
https://www.youtube.com/watch?v=0xlB0HXT520&feature=youtu.be
Flight times are 70minutes at sea level 25deg C, 55 minutes at 1600m ASL, 40deg C.
Additionaly an 18mpixel Canon stills camera, stablised in roll, is fitted in the belly bay , under the wing, as was in the original mk-II aircraft.
search for SurVoyeur on DiyD for other blogs on mk-I and mk-II if interested...
The Nampilot.
  • Brilliant !!!!!!!!!!!!!!
  • Hey nice gimbal!
    Looks that you are using slip rings there? If possible can you share which ones are you using?
    Also what is the weight of the gimbal including the sensor, a very nice build!
  • Hi there Pransh,
    All the casing parts are made from fibreglass/resin, using molds .
    Regards
    Joe
  • what material have you used for the gimbal casing ?
  • Hello Nikhil,
    In search for a solutions for our UAV design, we found your great design.
    We are building a nose rotating pod for our UAV, similar to yours.
    I have a some questions about the roll mechanism:
    In our design, the servo connected directly to the rotating part. Why did you put the pulley?
    Also, we are looking for the best servos for that mechanism. We think about the Align DS610, do you have another recommendations?for the stabilization we are using the pixhawk card.
    Thank You .
  • We are still at our analysis stage and haven't yet purchased a camera or accompanying lens. For this purpose based on your comments, I tried preparing a MATLAB script (Considering the FLIR Quark 640, 19mm lens, 120m AGL and 20m/s flight speed) to get in some initial numbers. Could you please check it out and tell me if I'm on the right track and if possible suggest some improvements to make it more accurate. (link to script on google drive
    Also could you share some information on how to derive the processing power required for processing the footage from the cameras. Because I feel even if the cameras are capable of high frame rates and resolution we would be limited by what our onboard processor will be able to handle. This would also help me choose an optimum processor.
    Thank You
    Camera.m
  • Nikhil,
    What camera are you using ( FLIR- TAU, Quark, etc) and what is the lens that you have fitted - From that info we can work out the field of view and therefore the ground coverage related to flight height AGL. This will give the ground movement rate per image pixel per unit time and then we can see at what speed the blur becomes unacceptable.
    Regards
    Joe
  • Thanks for the response.
    We are trying to build a UAV and are trying to figure out what is the fastest we can fly to have unnoticeable motion blur based on IR camera resolution of 640x480, 120m AGL and 7-9 fps ("slow video" due to export restrictions)
    Regards
  • Hi Nikhil,
    I am not to sure what effect you are referring to - there is certainly blur related to the camera frame rate and the rate at which the ground features pass in front of the camera, but flying at 18m/s and at 100meters AGL we do not notice the 'blur' at all. This type of artifact is related purely to the speed of movement of the ground features being imaged. At 30meters AGL and 18m/s flight speed, the image is quite un-viewable. However, a huge contributer to image blur is vibration, common on gas powered aircraft and multirotors. Since our plane is electric, single well balanced prop, we do not have a problem.
    Regards
    Joe
  • I had a question regarding the functioning of the IR camera. I was wondering if you experienced any motion blur from the IR footage and if you did how did you rectify it.
    Also would you happen to know what factors effect motion blur on IR cameras?
