Hello to All,
The purpose of this blog is to share with you some feedbacks about my flights experiences with the ArduPilot onboard.
ArduPilot on EasyGlider videos :
Flight plan mode, Fail Safe and RTH mode has been tested with the ArduPilot :
http://diydrones.com/video/flight-plan-mode-fail-safe-and
EasyGlider flight with ArduPilot in windy conditions:
http://diydrones.com/video/easyglider-flight-with
Photos Album :
http://diydrones.com/photo/albums/ardupilot-flight-on-easyglider
Jean-Louis Naudin
Email: JeanLouisN777@diydrones.com
DIY DRONES home page : http://diydrones.com/profile/JeanLouisNaudin
Comment by Jean-Louis Naudin on November 10, 2009 at 9:38am
Hello Nick,
Thanks for your comments, I haven't yet tested the no rudder version but for a well coordinated turn, I recommend strongly to use the mixing with the ailerons and the rudder (with a simple 3-Y) as mentionned in the diagram above.
Today, I have just updated my easyglider header file with some new fine tuning about the heading gain.
Look at : http://code.google.com/p/ardupilotdev/downloads/list
Now, flight plan is played like a music sheet with this setup and with the v2.4.3..
Jean-Louis
Comment by Jean-Louis Naudin on November 12, 2009 at 10:49am
Hello ArduPilots,
I have just released a new version (the v2.4.4) of my ArduPilot. This new version contains a very interesting feature: THE SELF LEARNING MODE....
This new feature is very usefull in the field, because you don't need to have an internet connection (google map) or a PC computer to create yourself a customized waypoints list, your ArduPilot will be able to Self-Learn its own flight plan in flight !!!
The Self-Learning mode works only on the version 2.4.4 (the JLN personnal version) ONLY.
You will find this update at : http://code.google.com/p/ardupilotdev/downloads/list
Now, I explain you how to record IN FLIGHT a flight plan to your ArduPilot UAV.
A) LEANING MODE :
PRE-LAUNCH:
A-1) The transmitter must be switched ON and the control button set in MANUAL MODE,
A-2) The "Remove Before Flight" (RBF) jumper must be connected,
A-3) Connect the Lipo battery to the ESC of your plane,
A-4) Wait the GPS-Fix (the blue led goes fix) and the Ailerons/Rudder moves quickly,
A-5) Remove the RBF,
A-6) Then RECONNECT THE RBF.
Your ArduPilot is now ready to Self-Learn your flight plan.
B) Just before the launch : You need to erase the previous stored flight plan before to learn a new one.
B-1) Hang your plane (be carefull of the propeller) then turn the control button of your transmitter from MANUAL MODE TO WAYPOINT MODE (the middle position by default) then quickly back to the MANUAL MODE again.
The propeller will start few seconds during this step.
Now, the previous flight plan has been erased in the Eeprom memory of the ArduPilot.
C) RECORDING THE FLIGHT PLAN :
C-1) The control button must be set in MANUAL MODE. Launch you plane and fly, when you want to record a waypoint, you simply need to turn the control button of your transmitter from MANUAL MODE TO WAYPOINT MODE (the middle position) then quickly back to the MANUAL MODE again. The plan will move quickly the ailerons to point you that the WP has been recorded...
So, you may record all the 3D Waypoints (lat, lon, alt) that you desire...
When all the flight plan has been recorded during your flight, land your plane.
D) REPLAYING YOUR FLIGHT PLAN
D-1) Disconnect the Lipo Battery
D-2) The RBF jumper is still in place on the ArduPilot and the transmitter ON and set in Manual mode,
D-3) Connect a new charged Lipo Battery
D-4) Wait for the GPS fix (the blue led fix and the quick motion of the servos)
D-5) REMOVE THE RBF jumper,
D-6) Launch your plane and now, you may run the recorded flight plan when you want by only turn the control button to WAYPOINT MODE....
Enjoy,
Best Regards,
Jean-Louis Naudin
Comment by Jordi Muñoz on November 12, 2009 at 12:03pm
Jason,
The new code i'm working on has a new feature you way want to include:
If you reconnect the bind plug after initializing it will disable the throttle for security... So you can switch to autopilote without turning on the motor. Just remove it before flaying. ;-)
Comment by Jean-Louis Naudin on November 13, 2009 at 12:28am
Hello Jordi and Jason,
I have now updated the v2.4.4 (Self-Learning mode version), this is now the v2.4.5 :
The reset of the wplist is done automaticaly in flight, during the first wp record. So, the step B is not required and the motor wont' turn...
The latest version v2.4.5 can be downloaded here : http://code.google.com/p/ardupilotdev/downloads/list
Jean-Louis
Comment by Peter Scott on July 20, 2010 at 1:42am
Good post....thanks for sharing.. very useful for me i will bookmark this for my future needed. thanks for a great source.Seeing all the above comments though, maybe I might have to keep looking.GPS
Comment
