iQuad Tilt-Rotor Quadcopter (v2) Flight Testing
After more than a year of design and development, I've built version 2 of the iQuad custom tilt-rotor quadcopter which is capable of achieving high forward speed by tilting its rotors forward in flight. After several days of flight testing and tuning, I was able to achieve stable hover and incredibly fast forward flight. Near the middle of the video, you can see the iQuad hitting a top speed of 53.3 miles per hour on the third flight of the day! This was achieved with a 40 degree forward tilt of the rotors.
For stability control, I'm using an APM 2.5+ and a modified version of the 3.0.1 arducopter firmware. Big thanks to R_Lefebvre and Gary McCray for convincing me to switch to the 3.0 version and other suggestions. To support tilt-rotors, I created a new body configuration, which adds servo control and does the proper mixing of the pitch, roll and yaw inputs depending on rotor tilt. I also added logging for the tilt input and servo angles, which was very helpful for debugging some initial stability problems. For the final phase of the project, I'm planning to add four wings that will wrap around the metal arms (and maybe some tail-fins), to allow a full transition to forward flight.
Here's another video of me having some fun with the iQuad. Near the middle of the video you can see the iQuad hovering in place while tilting forward/back.
Comment by Ron Isaksen on January 22, 2014 at 10:34pm
Selling them in the future?...
Comment by John Smith on February 1, 2014 at 4:23pm
Hey there
Nice little thing you going on there. I was wondering what's the torque rating for the servos you are using, and how did you came to choose that rating?
Keep on the good work!
Cheers
Comment by Ilya R. on March 2, 2014 at 5:35pm
Not planning to sell, but if enough people are interested, maybe =)
With regards to servos, I am using Hitec mini servos. The main consideration for me was small size and weight, and the ability to calibrate the end-points of the servos. The torque seems good enough, and they're also super-reliable. I haven't had any stripped gears even with some minor crashes.
Comment by Hollis Inman on September 29, 2014 at 9:14pm
I'm working on a tilt-rotor counter-rotating octo with wings optimized for tandem orientation (so that the engines will be inline similar to your craft). The airframe is full CF and sits on a 2m x 2m footprint. It utilizes horizontal and vertical stabilizers instead of the fins mentioned earlier in this thread. I'd be grateful for any help you could provide code-wise or pointing me in the right direction for programming arducopter for VTOL planes. I'm not sure how your wing design is going but it could be insightful to trade notes.
Comment by Ilya R. on June 5, 2016 at 11:26pm
Hi Hollis, sorry for the extremely slow reply. Haven't been too active in diydrones recently. To answer your question, I did make the wing design, but it was too heavy and hard to control. I also made a couple of other variants, but the tilt-rotor quad in the video was by far the fastest and most fun to fly. It seems there are a bunch of copy-cat projects making similar tilt-rotors now too. How is your project going?
Comment
