Hello friends!
We are introducing the new Professional Protogrammetry Quadcopter Harfang RTK. This is a Ready to Fly Drone, aimed to Professional users with a Low Price point and High End features. Flies 30+ minutes and complies with "light weight" standards!
3689711966?profile=originalBased on the familiar Pixhawk Autopilot, a mainframe made by France's Lab4Drone and broadly used Spain's North RTKite GNSS RTK receiver, the Harfang RTK is fully made in Europe and supplied worldwide.
The RTKite GNSS Receivers allows to eliminate or minimize the GCP on the field while incredibly stabilizing the navigation with its millimetric real time accuracy. It can connect directly to the available NTRIP CORS stations with its onboard mobile cellular modem, Receive corrections from an RTK Ground base by GPRS through the exclusive AutoCaster system or use the Pixhawk RF from the ground control to receive the RTK corrections from an SmaRTK Base receiver.
3689711986?profile=original
This carefully crafted collaboration between a high-end drone producer and a professional RTK supplier, makes sure that the integration is seamless and the most easy to use out of the box.
3689711911?profile=original
The exclusive Patented drone mainframe is designed from high-quality carbon fiber rods and a simplistic Snap-On design where the spare parts can be produced in house by the end user by simple rod cutting and 3D-Printing if needed, greatly reducing the repairment costs on site.
3689711800?profile=original
The Harfang RTK Drone with North RTKite GNSS RTK Receiver, comes with a selection of entry-level Sony Camera, Professional Sigma camera or Multi-Spectral Parrot Sequoya camera, to fit most purposes.
3689711920?profile=original
Regarding the GNSS it can operate on either Single, RTK (Real Time Kinematic) millimetric, PPK (Post Processed Kinematic) millimetric and a vast array of data logs and formats including all the NMEA standards, Novatel's Raw and Bestpos, RTCM, Trimble's CRM, RINEX and many more.
The Harfang RTK drone, as well as the RTKite receiver and the ground SmaRTK Base receivers can be easily ordered online and you can contact us at North Group for any special set configuration not available as ready-made sets.
Just drop us a message!
  • Cual es el costo del equipo completo ... Base y drone... slds
  • Sound is good !  Thank You !
  • Hello Roy! Yes the drone is a specific design made from Lab4Drones France, aimed to easy assembly and repair by click-on only and produced serially. We will publish it soon as a ready to order package from gnssrtkmodule.com but we can send you right now the information by email if you need, just drop us a line to emea@northgps.com
    Thanks!
    GPS Home - GNSS RTK Module - SmaRTK, RTKite, PPKoord Receivers
    GNSS RTK - System-On-Module Real Time Kinematic GPS and GLONASS Receiver for UAV, industrial and embedded applications.
  • This product is very good ! The drone is custom made ? Can order this drone?
  • Welcome, cheers!
  • Ahh, I'm sorry, now i see same question and your answer above. Thank you.
  • Hello Alexey! The 4th picture is just the snap on design of the original mainframe with only L1. It was adjusted to have bigger space to fit the L1+L2 RTKite inside and a hole and base for the Helical antenna. Cheers!
  • Bernardo, this drone uses RTK receiver only for geotagging? On 4th picture I see somethink like muchroom GPS receiver.
  • Hello, of course! The main function of the RTKite is to provide millimetric accuracy to the drone, so it can be used for both the Geotagging and the Navigation. On the Harfang drone it is the only GPS to provide both functions.
    On this video we are testing both Static and Autonomous flight using RTK corrected from France's TERIA CORS network for millimetric positioning: https://youtu.be/UCWYeK4q79s
  • Hello Bernardo, Can you use RTK as flight GPS?, Can the pixhawk use this accuracy for navigate?
