What would you like to see in a thermal pan tilt platform to make it effective for UAV usage?
3689490963?profile=original
I am with a company called SPI Corp and we manufacture a low cost multi sensor pan tilt platform called the M1-D. The M1-D initially was developed for use on ground vehicles but due to its light weight, small size and low cost it has become very popular with folks in the aerial imaging world including both manned and unmanned craft. We are anxious to make this an even better product for UAV usage especially in the low cost market. We are reaching out to the UAV community for help in this endeavor (especially you guys at DIY Drones).  What we would like to know is what technical features would make our system even better for use in UAV's? If you could have anything you want in a low cost UAV Gimbal imaging system what would you ask for? What would be the bare minimum you would need to make the M1-D pan tilt thermal camera a workable UAV solution?  Current imaging systems are extremely expensive. It is our hope that by starting with our current low cost solution, and with a little help from the community, we can come up with a low cost UAV solution that will enable everyone to incorporate advanced imaging into their UAV project.
Our current system specs:
Fully enclosed pan tilt gimbal
Sensor Payload - Thermal Imaging, CCTV and Laser Pointer
Diameter of ball - 4.5"
Diameter of base - 5"
Height - 6.5"
Weight ~ 2lbs.
Pan - 360 degree continuous
Tilt - 90 degree
Pan Tilt Speed - Pan: 0.05~220°/sec; Tilt: 0.03~140°/sec
Video Output - Analog Composite single line NTSC or PAL
Communication Camera Control - RS/485 PELCO-D protocol
Inverted Mounting - Yes capable
Hardware specs such as size and weight are obviously difficult to change. What are the key features that you would need to integrate into your UAV project? Are there specific interfaces that are commonly used? Please post comments and let us know what you would like to see in the M1-D to make it even better for UAV imaging.
We look forward to your input.
Thank you
Randall Kolchins
SPI CORP
www.x20.org
  • Hi Randal, what are some of the new features of your m2-d gimbal
  • Keep us updated!!!
  • Hi Randall,
    Should we expect a product anytime in the near future? Im sure this would be on high demand.
  • Sorry, we have been away from the forum for a while. The M1-D is moving really well and being used/tested by a number of UAV manufacturer/integrators. We have looked at the feedback from the board and there are solutions out there that convert the PWM to Pelco to control the PT thermal camera. We can also do a basic camera that the user can integrate into their own system. Yes we can have the camera measure temperature as well.
  • Hello is it possible to get temperature measurements from the data collected with this camera?.
  • 300km
    Hi Randall and co
    Any progress? This thread just dried up in January.
    I think Sandro summed up what I'm interested in
    I believe that all you guys need to do is create just a small thermal cam with a well shielded "cubic" metallic enclosure and a pin-out containing GND, VCC and Video_OUT. So, we can buy or create our own pan/tilt/roll gimbal or pod devices.
  • 300km
    Hi Randall and co
  • I am wondering, is there any more news on this project?
  • Fantastic, if you get it sorted, I will be a customer.
  • Thanks for the reply Randall!  Good luck on everything!
