My DIY Retract & Gimbal Mount
Test run using bamboo skewers to hold the retracts aligned in place
a6344218-6-a6344182-229-PC180117.jpg?width=388
a6344222-237-a6344164-165-PC180115.jpg?width=100
a6344223-71-a6344163-68-PC180112.jpg?width=150
a6344224-119-a6344166-13-PC180110.jpg?width=250
3689564309?profile=original
3689564232?profile=original
3689564272?profile=original
I've been working on this and decided I need to find someone to produce the main plate for mounting of the gimbal and servos, or at least a render file for me to find a fabricator at a reduced price
Unless I can arrange a group order for plates somehow
The design is quite simple and parts are easily found to build one, besides the mounting plate itself
It requires:
2 - Retract servos http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=23483
2 - Coax Connectors http://www.ebay.ca/itm/151079759256
2 - Coax Couplers http://www.ebay.ca/itm/321206494080
2 - 4mm diameter nails
2 - 12mm OD x 10mm ID 200mm Long Tubing http://www.ebay.com/itm/111176377084
Epoxy & CA Glue
Tools required involve Something to cut the nail & Tubing to the needed lengths
A hot air gun or something to heat the coupler to melt the inside and remove the centre pin Maybe a hammer or vice, A hacksaw
I started by heating & removing the centre from the couplers and inserted the nail while the coupler was still pliable inside
measured the needed nail after the coupler to replace the stock retract pins and cut the extra off
Made a notch in the nail shaft to match the set screws on the retracts
the tubes only involved epoxying the coax connectors in one end and cutting to the desired lengths
shaping the leg end to join the foot tube to provide a uniform joint with the curve of the foot tube
I used some spare aluminum tail tubes like these as my gear and epoxied them together to form the "T"
26" Double Horse Helicopter Tail Booms http://www.ebay.ca/itm/321102071864
The gimbal I'm using and designed the mounting holes from:
Gimbal Mount http://www.ebay.com/itm/171136254422
Gimbal Motors http://www.ebay.com/itm/121185850081
my idea is to make the top plate rubber anti vibe mount holes in the finished retract and gimbal plate thus the need for the top plate on the original gimbal mount will be omitted and the rubbers would be attached to the new plate instead
  • I had to add aluminum plates to provide a stop point for the leg servos
    if these changes in the design were done, the retract plate itself would provide the stop itself
    3701664721?profile=originalBesides that it works great
    https://storage.ning.com/topology/rest/1.0/file/get/3701664917?profile=original
  • a6520021-227-P2180063.JPG?width=450
  • Thanks,
    I still need a cf version, this one is painted lol
    I have to find a good supplier for cf plate still, been busy tho
  • Looking good!
  • 3701663933?profile=original3701664004?profile=originalMounting holes or clamps still to be decided
  • Assembled with adapters and 16mm tubes
    3701660164?profile=original
    closeup
    3701660115?profile=original
  • adapters
    3692944470?profile=original
  • A 3D Printed adapter made for a test solution over the aluminum one
    3692943366?profile=original
    a6464244-182-Retract%20Adapter.png?width=400
  • another update...
    a6460089-50-P1280072.jpg?width=400
    a6460090-138-P1280073.jpg?width=400
    Need to produce some other adapters to suit the larger inner diameter tubes
  • That looks great Charles I will look into the options with carbon. Glad everything fits like it should.
