Check it out: an all-in-one telemetry kit for ArduPilotMega, all set up and ready to go! No more fussing around with Xbee configuration. $165 for the total, which includes the custom configuration.
In this kit you will find everything you need to add telemetry features to your aircraft set up. The Xbee modules come paired up and ready to use! Included with this kit:- 1x XtreamBee Board (The one manufactured by DIYDrones!), including the two female connectors and right angle connectors.
- 1x XBee-PRO 900 extended range module w/ RPSMA connector and duck antenna
- 1x XBee-PRO 900 extended range module w/ wire antenna
- 1x Xbee Explorer Dongle (USB adapter for the Xbee module!)
Nice TM kit! Plug and play! Do you test each kit before shipping?
Ante,
You can add a SMA connector to the wire Xbee, but requires some good skills, I have replaced my worn out wire antenna too.
45 members
1472 members
282 members
470 members
57 members
Powered by
