Opensourcing ESC work
3689658789?profile=originalSo almost a year ago, I posted about how I started work on a field oriented control ESC:
Redesigning multirotor ESC's
Some people in the comments already said how they made their own or started work on different ESC's. I went through 5 iterations of the ESC after the post.
Unfortunately, I never got any hardware working reliably for pretty simple issues in the end, which is frustrating. Primarily, I could never get the buck boosters of the TI DVR830x to work reliably and there were issues with SPI voltage and behavor. This caused a failure of 8-9 out of 10 boards or sometimes an entire batch. To produce one batch here is expensive: 60% import costs, $40 shipping for 2 boxes (one boards, one components) and then there's the currency rate of R$3 to the $1. In the end, to produce one batch here feels like spending $1200 dollars if I were in the US.
Important: I'm not saying the booster of the chip doesn't work correct, but that it's probably something in the process of my production (the "pizza oven bake") or the design of the component values around it or routing of the board.
Anyway, moving on... I did huge amounts of research into field oriented control. I built a FOC simulator in python and there's some 150MB of documents related to FOC implementations, ranging from presentations of TI about the subject to application notes, research papers, etc, plus I include some remnants of the board designs. Obviously, no point including boards of failing hardware, so just the schematics...
From the image above, all blocks at the top are really easy. They're only conversions from 3-axis to 2-axis models using clarke/park transforms. The difficult part is the "angle and rpm estimator", which is where the magic really happens. Eroding all complexity... it's trying to figure out bemf magnitudes from the Ialpha and Ibeta currents (in a 2-axis view), so that over a couple of samples it can converge to an angle. Another piece of code then gets this angle estimate and figures out the rpm, which is fed back into the angle estimate, because the rpm doesn't change all that quick. All that's left is tuning and the correct L and R inputs for the motor you're using.
The repository is here, along with a README on where to find the stuff.
https://github.com/gtoonstra/foc_esc
Disclaimer: No guarantees that any of this stuff actually works...
  • I did use that A4960 chip, but had to dump it because it was taken off the market and also it's not suitable for projects that involve this kind of motor drive. What you could do is look for A4960 projects (they are around) and look into the source code there.
    Personally, the ESC you're describing is already so much of a commodity, that I'm not sure why you'd build one yourself. The costs will surely be higher than buying one from China.
    To get up to speed with how this could work, I recommend you find the BLDC controller thread on rcgroups.com, that's the best thread out there regarding BLDC control of all types with all kinds of technologies.
  • Hi Gerard!
    I see you've been involved in a DIY ESC project over the past year.
    I'm just starting out to see if a DIY ESC project is feasible.
    I want to start out with something simple like an airplane ESC. Just something with a simple throttle control. If I can get that working, then maybe a more difficult quad-copter type firmware control can be addressed.
    I looked at some of your open source schematics concerning the TI DVR8030x. It looks way too complex for me.
    I want to use an ATMega chip, and I don't want to deal will all the intricacies of driving all the FET signals off the ATMega. That means employing some sort of Controller Chip that is smarter than a simple driver. I need something the serves as a black box...easily driven by the Microcontroller...eliminating a lot of the complexity by handling all the commutation calculations in silicon of the controller.
    To those ends, have you ever looked at the Allegro A4963 chip? According to the Datasheet, it was introduced in October of 2014. This newer chip is totally different from the Allegro A4960, which has been around since 2011.
    The A4693 Press Release says:
    "This new motor controller is targeted at the consumer, industrial and white goods markets with end applications to include: pumps, blowers, power and garden tools, hair dryers, portable mixers, and airborne drones."
    It is only a 20-pin chip.
    There is a Voltage pin, a Ground pin, and a Ground pad.
    The CPU side contains:
    - 4-pins of SPI bus,
    - 1-PWM line to control the speed.
    - 1 Fault output line.
    - 1 Speed indicator output line.
    The final 11-pins drive the FET side.
    It looks like it can be put into various usage modes...with the "closed-loop speed control mode" being the most applicable to what I want in an ESC.
    I wish there were some projects out there using it, and some better documentation. Allegro has absolutely nothing in the way of White Papers or AppNotes.
    I know it will take multiple readings of the datasheet to begin to wrap my head around the concepts.
  • FPU is good as you can write code with SI units (e.g. you can have current in amperes, voltages in volts, speed in RPM etc), which is not really efficient on fixed point uCs, but if you use manufacturers libraries for FOC, which are optimized to take full advantage of uC features and you don't obsess with having variables in float/SI units, then in my opinion there is no difference between FPU and no FPU.
    Sorry to hear you had so many issues with DRV830x, for me it has been working well - only problem I have is lack of time to continue with development :). I am planning to make a test stand with two motors, connected back to back, because it's scary (and dangerous) having 15 inch CF prop rotating at 5000 RPM three feet away...
  • Hi Jure,
    I noticed the freescale libraries later on. Part of the exercise was to implement this myself and if you look at the algorithm, it looks pretty trivial. The thing you do need is a good processor with floating point.
    Symptoms of the failures:
    • I'd get 5V at the LDO regulator to produce 3.3v. Then when I put a load on 3v3, 5V collapsed to 0.8v.
    • The majority of the failures of the first couple of runs (DRV8301) were related to SPI not working. So the power supply would be ok, but the chip was unusable because it did not respond to SPI commands.
    • So I moved on to DRV8302 instead.
    • Other issues were actually related to how GND was connected to the chip and the MCU and how the routing is done from the current shunts (resistors) to the chip. That is very tricky to get right and requires a lot of attention. So in the first batch it was a rather naive route, which caused 1.8V noise on the current sensing line due to amplification of the noise. To put this into context, if you want to build long endurance ESC's with current sensors, 20mV is the ripple and 1A with a 0.001 resistor gives you 1mV signal, which needs to be amplified 40x before it goes to the MCU. So any design decisions on the current sensor eventually dictate the range (current wise) your ESC is useful for (it's not just the mosfets anymore). Obviously that was fixed in the 2nd batch with 0.004 resistors and now 0.008 ones.
    A guy I know from a client helped me out to resolder the chips, he has a lot of experience with SMD. Alas, that didn't work and didn't have any result. It was a replacement chip even.
    Philip, going to send you a private msg about that.
  • What were the simptoms of the failures? I hand-made ~5 or 6 boards and had no problems with any of them.
    Have you considered using libraries for FOC? I am using Freescale's and got motor turning over a weekend.
  • Gerard, do you have any interest in participating on the Pixhawk UAVCAN ESC project, I am sure you would be welcome. Let me know.
  • Btw, one of the things I didn't even get close to was a technique to further improve the efficiency of the ESC. Most implementations use a simple PWM scheme for the motor actuation. When vector control is already used, most of the computational complexity of Space Vector Modulation (SVM) is also solved, so you can wrap SVM actuation into the algorithm when going back from the 2-axis to the 3-axis model. (clark/park or park/clark, whichever). SVM actuation reduces switching losses.
    I was also going to look at introducing the third harmonic into the sine wave table. The reason for that is that the regular sine wave actuation, you may not have as much max. torque vs. a straightforward back-emf null-crossing detector and a simple on/off scheme for the coil being actuated at the moment. Apparently you may lose as much as 15% torque.  Introducing the third-harmonic returns most of that lost torque.
  • The ground pad was soldered. The docs contain the datasheets with additional info on the BoostXL board (the board that has the driver chip pre-soldered), which contains more info on how to route, solder and place components.
    The chip was soldered through SMD paste in a "pizza oven", which certainly does get to the temperature. I manually eased the heating process by turning things on and off, so there's time for the heat to disspiate.
    Obviously, this is still far from a controlled process, but I've seen people soldering this by hand.
    On the recent boards, I made one larger hole at the back (where you're supposed to have vias anyway), to be able to inspect whether the solder has actually reflowed there, which it did.
  • Question, how did you solder DRV830x's? It is importaint to solder exposed pad to ground plane, otherwise it will not work properly.
  • good to know some update on px esc!
