Passive thrust vectoring with anti vibration mounts.
 Have constructed an enclosed ‘H’ frame carbon/Kevlar quad with soft mount front and rear arms for vibration reduction. Initially yaw was awful as the arms tilted in the wrong direction and opposed any motor torque so I had to stiffen the mounts to prevent yaw reversal. Now I have reversed the motors in the code and the tilt actually helps the yaw. The mounts on the video are very soft, just to help demonstrate the movement but I think they were bottoming out.
Am quite pleased with the lack of vibration showing on the camera.
Apart from the motor reverse all parameters are completely stock. Will tweak them when I get some time.
Vince
Comment by Vince Hogg on February 24, 2013 at 3:01pm
Mk 2 taking shape.
Didn’t go for the pig ugly one. I really like having a front and back for orientation.
New one has motor tubes going through so one snapped O ring is no longer a problem.
Comment by Lito P on February 27, 2013 at 1:33pm
That is beyond impressive...wow!
Comment by Eliana Stefani on March 12, 2013 at 10:51pm
I'm new to this, and am trying to mount some motors to a carbon fiber rod, and attach those rods to my frame. How did you do that in this video? I am planning in the future to try forward thrust vectoring for my quad too! Any ideas for the attachments? Either static (like you have on your H-quad) or dynamic for thrust-vectoring? Thanks, and good job on laying the carbon for the frame!
Comment by Vince Hogg on March 13, 2013 at 2:53am
Hi Eliana.
Did you see the pics at the start of the blog? They should show how the tube is mounted, on o rings with zip-tie to the metal angle.
The new frame uses 5mm carbon tube to hold the o rings.
These are the tube mounts, also used to hold the motors on – but there are lighter mounts for that.
http://www.ebay.co.uk/itm/4-x-Metal-Motor-Mount-Tube-Mount-for-X450...
If you use those with o rings you must take off the sharp edges from machining, they will cut the rings. I used a dremel.
Did you see the other blog?
http://diydrones.com/profiles/blogs/mk-ii-h-frame-quad-now-flying.
Vince
Comment
