I've ported MinimOSD to Remzibi's hardware
Hello everyone. Recently I port the MinimOSD to the Remzibi OSD's harware, so a poor man can enjoy MinimOSD's convenience now (no need to modify APM's software anymore).
Because of the limited flash space of Atmega16, the code of OSD is slightly changed, and it is not compatible with Michael's original config tool. So I adapt the config tool as well.
The Remzibi's OSD uses Megaload bootloader, so please use the Megaload programmer to upload the firmware. (The config tool can also upload the firmware, but I have to admit that it is not quite good right now.)
Anyway, here is the firmware and config tool, and here is the source code.
Thank binzi for providing the hardware.
Comment by Sandro Benigno on March 21, 2012 at 4:11am
@Hazy... WTF??? LOL. It needs a patent: "BGA Hair". =)
Comment by Wattas on March 22, 2012 at 2:19am
Excellent!I tried APM1 with Arduplane2.27.It works.No sattelites count only,I think it is because I'm using ublox GPS.It would be good to show current consumption in mAh.Thanks for this big job.
Comment by Ricardo Affonso on March 22, 2012 at 4:45pm
great thread!
i'm new on uav world, got my APM2 a few weeks ago and my remzibi arrived today, bought at goodluckbuy.com. Can you make a step-by-step tutorial to help a little? i was thinking about flying with only the remzibi while i make simulation tests with apm, but everything is already working fine on xplane, maybe i can put everything together right now.
but i'm affraid of doing anything wrong, got apm2 and its airspeed sensor from 3dr, current sensor from flytron and remzibi from goodluckbuy.com, already noticed that the best options would be buying current sensor from attopilot and miniminOSD instead of remzibi.
Comment by hazy on March 22, 2012 at 9:41pm
@Affonso: You can follow the tutorial of ArduCAM at this moment. Everything is same except uploading the firmware. I may write a document later. However, according to Dyer's report, it seems there are some issues in my code when connecting with APM2. I cannot confirm them right now since I have APM1 only.
Anyway, you can recover the original Remzibi's firmware if something is wrong.  So don't be afraid. Just be careful to do enough test on the ground before you fly.
Comment by Graham Dyer on March 25, 2012 at 2:43am
Hi Hazy, any further news on getting this to work with APM2, can I send you a log or help in any other way?
Comment by hazy on March 25, 2012 at 6:38pm
Hi Dyer, a tlog file will be helpful. Please send to my email (hazyhxj@gmail.com), thank you.
Comment by Graham Dyer on March 26, 2012 at 8:07am
Just tested again trying to get you a tlog or log but it now works fine with APM2, last time it bootlooped but this time it reboots and then shows the OSD with APM2 armed. Not sure why but great, it does work with APM2!
Good one!
Graham
Comment by Ricardo Affonso on March 26, 2012 at 8:11am
i'll try not to run before walk..i've just decided that first i'll install remzibi standalone to fly fpv and keep up simulation tests with APM2 and XPlane. after everything is running ok on both parts, i'll try apm on the plane and the remzibi integration. Hope that by that time you already have fixed all the bugs on this code, seems very good!
Comment by hazy on March 26, 2012 at 7:21pm
@Dyer, I'm happy to hear it works. But the rebooting is still not expected. Please test it further before you fly. :)
Comment by Graham Dyer on March 26, 2012 at 10:13pm
The advantage of this is that it works natively with APM whereas getting the Remzibi's OSD to work with APM is not simple.
Hazy, when I say reboot what happens is that the normal HUD screen is shown, then when APM is armed the screen shows the startup up message briefly, then "requesting streams" then back to the normal HUD screen
Comment
