3689489678?profile=original
When the ublox 6 series modules were released, I noted that the 6T and 6P modules provided access to the raw carrier phase measurements, and I started thinking about how to use this capability.  My connections through my university research appointment weren't strong enough to get ublox to sample a dev kit to me (they generally don't sample them at all).  Jordi and Chris from 3DRobotics.com were kind enough to use their customer relationship with ublox to get a sample 6T module and provided it to me mounted on the standard DIYDrones ublox LEA-6 module.  So mine looks just like the one above, except it has a 6T module instead of a 6H.
My prime curiosity was how good the carrier phase measurements from this module were.  The datasheet indicates that carrier phase measurements are available, but gives no specs about their accuracy.  So I had no idea if they would be of value.  Well, with a module in hand, some measurements made, and post-processing completed, I can tell you that there is tremendous potential here, but a lot of work before this is something ready for everyday use.
OK, what is carrier phase and why do I care?
A carrier phase measurement is a measurement of the phase of the arriving carrier wave signal from the gps satellite.  Think of it this way - as the radio signal from the GPS satellite travels from the satellite to your receiver it completes some fractional number of cycles of oscillation.  That means that the distance from the satellite receiver to you is some fractional number of wavelengths - say 100 million and 1/2 wavelengths.  The carrier phase measurement gives you the fractional value of 1/2 wavelength, or 180 degrees of phase.  That in itself is almost useless.  Fortunately the gps module gives us something a little better than that.  What it reports is the phase change (or the number of wavelengths of distance change) between the satellite and the receiver from one measurement epoch to the next.  So what we really have is a measurement of the change in distance between the satellite and the receiver over a known period of time.  And so theoretically, given that we know something about the location and velocity of all the satellites we should be able to use this information to calculate the (3D) velocity of the receiver.  Just one more thought on this topic - we could do the same thing with pseudo-range or Doppler measurements, which the receiver also makes, but carrier phase measurements have the potential to be orders of magnitude more accurate.
Nice, but what about position?
Well, the technique that I will describe below has some applicability to making very accurate position measurements, but lets just say it is really hard and is the kind of thing that only happens (still a relatively small number of) military gps with very large price tags.  I'll say some more about this later.  For now, we will just be looking at making velocity measurements.
OK, but what will we do with a great velocity measurement?
Well, imagine how much better position hold could work in a copter if the autopilot knew its 3D velocity vector to an accuracy of 5 millimeters per second.  Yeah, time for a double-take.  I said millimeters per second.  My initial test yielded a velocity resolution of 1 millimeter per second and an accuracy of better than 5 millimeters per second at a 5 Hz update rate.
There are lots of other things we can do with a better velocity estimate, like better acceleration modelling in the AHRS system, etc.
Let's see the data.
OK.  I have run two tests so far.  The first turned out fantastic.  The second had some difficulties, but still shows immense promise.  Below is a plot of the velocity estimate error during the first test.  This represents a bit over 5 minutes of data with samples at 5 Hz.
3689489765?profile=original
OK - let me describe a few things in this plot.  First, note that there are 5 `spikes' where the error is above 0.1 m/s.  These are 5 samples where the receiver did not have carrier phase lock on at least 4 satellites, and you need 4 satellites to get a valid solution.  For individual samples like this you can generally re-use the last velocity estimate.  There are also around 10 samples where the error is on the order of 4 or 5 cm/s.  These are samples where the receiver only had 4 satellites with carrier phase lock.  The accuracy gets better when the receiver has more satellites with carrier phase lock.
You may be wondering what my "truth data" was.  Well, it was simply that the module was just sitting on the ground in my back yard, so the truth was 0 velocity in the Earth centered Earth fixed (ECEF, WGS84 for example) frame.  This is not at all cheating as the velocity relative to the ground is irrelevant - we are still making a velocity estimate based on measurements of the velocity between the satellites and the receiver, and the satellites are all moving at roughly 14,000 km/hour in various directions.  The relative velocities between the satellites and the receiver are on the order of thousands of kilometers per hour, and from this we are able to deduce motion on the millimeter per second scale.
Unfortunately maintaining carrier phase lock is not as easy as tracking a satellite.  On the second test in similar conditions I only got carrier phase lock on 4+ satellites about 75% of the time, leaving many periods of several seconds with no valid measurements available.  On the second test the reduced accuracy of the velocity measurement was more apparent with accuracy on the order of 0.1 m/s with 4 satellites and 0.02 m/s with 5 satellites.  Even so, 0.02 m/s is a very impressive number.
How did you do it?
I did all this with data recorded using ublox UCenter and post processing using MATLab.  There is no reason that C code cannot be developed to do this in real time, although it probably requires too much processing power to add to an 8 bit autpilot.  Fortunately 32 bit hobbyist autopilots are becoming reality.  My method was really a reflection on my lack of time for this sort of project at present.  So, here is what I did:
  • I used the 6T module to collect raw carrier phase measurement data.  Tridge supplied a Python script to convert the ublox formatted file to a human readable file.  I did some further formatting on it and imported it into MATLab as a data structure.
  • I used the GPS broadcast Ephemeris to compute the position of all the GPS satellites for which there were measurements at each time epoch, and translated these positions into the ECEF coordinate frame.
  •  I differenced the computed ranges between adjacent epochs and set up a linearized least squares estimate of the receiver velocity using unit vectors in the directions from the receiver to the various satellites as a weighting matrix.  The final estimate can be translated into the ENU or NED navigation frame for use.
I thought that approach would work great, but it failed completely, and it took me a while to figure out why.  The reason is that although the receiver clock bias is not needed in a velocity solution like it is in a position least squares solution, the receiver clock drift rate is not insignificant for inexpensive modules like ublox and it completely messes up the velocity estimate if it is not accounted for in the sample to sample carrier phase change.  Simply put, the receiver clock is not only running at a somewhat incorrect frequency (the clock bias - which is an error in the pseudo-range measurements) but its frequency is moving around and the rate of change of the frequency shows up as a velocity error in the carrier phase measurements.  So, I modified my least squares estimation to estimate both the 3D velocity vector and the drift rate of the receiver clock.  This worked great.
Work left to do
Several things need to happen to move this forward.  First, I need to investigate how big a problem exists with the module not being able to maintain carrier phase lock on enough satellites and what conditions make that better/worse.  Second, the issues with running this in real time on a drone need to be hashed out.  I don't really know how processor intensive this code will be when optimized, but likely it will need to wait for the 32 bit processors as it is fairly math intensive.  Finally code needs to be developed as I did this all with MATLab and borrowed a lot of proprietary scripts from research associates…
A few more things if you are interested - Cycle slip, Integer ambiguities...
The reason that it is difficult to use carrier phase measurements in a position solution is because of the "Integer Ambiguity".  The Integer Ambiguity is the unknown number of full cycles of the carrier wave between the satellite and the receiver.  See the picture below.
3689489819?profile=original
Here we see a satellite in motion and the phase measurement at two times.  The carrier phase measurement gives us the number of "Counted Cycles", but we have no idea how many cycles are in the Ambuguity.  There are techniques available to resolve the ambiguity, but generally these take a very large amount of processing power, take a long time, and are difficult to implement for platforms with dynamic motion.  We can maintain a sum of the Counted Cycles and do a variety of things with it.  This is one method used in RTK in a lot of agricultural applications, etc.  But every time we loose carrier phase lock we have to discard the sum and start over.  This is termed cycle slip.
I mentioned that gps receivers have a harder time maintaining carrier phase lock than just tracking a satellite.  The tracking loops in a gps receiver are fairly complicated.  There are simultaneous loops tracking both the code delay and Doppler frequency for both the in-phase and quadrature channels.  These loops use a power measurement from the combined I and Q channels in their discriminator to maintain lock in these loops.  However the carrier phase lock generally has to rely on a single channel and has other challenges. This is too bad because it is commonplace for the receiver to be able to track between 8 and 10 satellites in an open sky.  However, my 2nd test showed as poor as only 75% of the time with 4+ satellites maintaining carrier phase lock.  This will be the critical factor to investigate to move forward.
  • I know this is quite old, but do you have the source code for this? I've been trying to find an example of TDCP velocity calculation without much luck
  • Thanks Doug!
    I've wrestled with Allan variance in the past when deciphering gyro data sheets, hopefully it won't come to that again. Assuming I can get all of this working, I'll try it with both parts. I'd like to use the -P variants just to be able to take advantage of it's more precise output as a fall back.
    I'll post any interesting results etc. once I've managed to achieve something.
    It could affect the pseudo range, Doppler and carrier phase measurements , but the extent to which it would I don't know.  Velocity measurement assumes there is a drift rate in the RX clock.  If the regular XO clock drift is nicely linear with time then there will be no gain with a TCXO.  Clock drift is a pretty wild subject and hard to get one's head around.  You can do some background research on Allan variance and the like to get a feel for it.  It is not an intuitive subject.
    The T parts are marketed for time transfer; estimation of GPS time is critical to some people and I'm sure that is why they are using a TCXO.  Over relatively short time spans (minutes) a TXCO is as good as an atomic clock.  There are lots of users of GPS in things like the financial industries who are very concerned with exactly what time it is and don't care about the GPS position/velocity.  The TXCO will give a better time estimate for sure.  I have seen a single epoch anomaly with a 5P that I suspect was due to clock steering and a TXCO would probably fix that issue.
  • Hi Doug,
    I just realized that the NEO-7P doesn't have the more stable TCXO oscillator as found in the -T parts.
    Do you have any idea if this will affect the measurement of the carrier phase?
    As my order hasn't shipped I'm going to play it safe and get the -T part instead!
    It's interesting that the -P part uses carrier phase information for its <1m PPP fixes. Naively I would have thought that having a more accurate TXCO would be beneficial, but perhaps not... I don't know enough about how the electronics determines the carrier phase value and whether or not clock accuracy is a critical factor.
    Any thoughts?
  • Many thanks Doug!
    That makes sense and doesn't sound so bad. The acceleration aspect you mentioned is interesting, hopefully for my application it's not going to be a problem as I'm just intending to use the approach to maintain a fixed hover. It would be great to hear how you get on!
    All I need now is for my NEO-7P to arrive and I can start having fun!
    Hello Max,
    At each measurement epoch the receiver clock error is modeled as a fixed drift rate (s/s).  This is all that is possible/needed as the velocity solution is a least squares calculation using data from a single measurement period.
    Interestingly, I have been doing some more work on this topic just now.  I have found that the velocity accuracy is very good if the gps receiver is stationary or moving with a constant speed/direction, but accelerating motion degrades the velocity accuracy significantly.  A cyclical 1g @ 1 Hz acceleration reduces accuracy by the order of 100.   This is due to the satellite channel tracking loops being able to have little or no steady state error for a linear Doppler change with time, but not being able to remove error caused by non-linear Doppler change, which is seen with accelerating motion.  I am trying to characterize the performance of the tracking loops but this is a bit of a challenge.
  • Doug, do you have any further details that you can share on how you modeled the receiver clock errors in your calculation?
    I ask as I'm just about to have a go at recreating your experiment. I'm doing this for mostly for fun but also to incorporate into my on-going DIY drone experiments. I can see that this is going to be an adventure and I'm looking forward to the challenge!
  • from above , Dougs comment "- conceptually Doppler measurements and carrier phase change measurements are the same, but the way they are made in a gps receiver is very different." I am not an expert in the measurement of doppler in GPS receivers. I do know a little about how it was done in a high end receiver designed by JPL call the Turbo Rogue. The carrier loop was all digital and set phase and rate to best estimate from last iteration. At the end of the integration interval the phase residual was measured using I/Q samples and a arctan detector. Since the phase was set to near zero error at start of iteration any phase error at the end was due to accel term of observed SV. The phase residual was integrated to produce estimates of carrier phase and carrier phase rate. The carrier phase rate is of course  an estimate of doppler. If receivers clock rate error is zero as well as SV clock rate error is zero this estimate is nearly equal to the real doppler once scaled. In this receiver method I cant see a 2 order of magnitude diff between carrier phase and doppler measurements.
  • Hi Doug,
    I'm building my own DGPS system for use within my Masters project and was wondering if you would be able to help me by taking a look at what I've done so far.
    Im wanting to get sub meter accuracy and using the U-blox NEO-6P chip to calculate my corrections.
    Any help would be greatly appreciated.
