3689516498?profile=original
I have a thought to use cellular technology to pipe video and data over a UDP connection.  This is nothing, however, I haven't seen a lot of support for the usage of 4G/LTE which allows up to 100mbps speeds.  Has anyone ever read up on this pico board?  I'ts available from min-box.com.  The same place I received my mini-PC for my GCS.
I had this idea about hosting a UDP server on board the aircraft with this pico board.  Then routing all traffic through a VPN tunnel where it will be connected to the GCS via internet/VPN tunneling.
The APM will connect to the board via serial I/O.  The tricky part (for me) will be routing that serial traffic over a UDP connection.  Any idea a simple(r) way to do this with Linux instead of any software-based routing procedures?  I very familiar with Linux, just haven't done any network routing inside a client-only environment.
Any thoughts or concerns are more than welcome!
  • Yes John, the Pi has it's weaknesses. But there are other small Linux devices with Quad 1.7Ghz and lot of power compared to the Pi.
  • @Arttu
    Never really had any issues with my devices - ideally when it fails the device should just return home.
    @Tommy
    well let just say I am not a big fan of raspbery PI. Read a lot about problems with compatible devices and having to use powered hubs. Plus that thing draws at least 5W IIRC.
  • Tommy I am looking forward to a blog writeup on your setup. I think I might go a very similar fashion.
  • @John: It's not complicated at all. My 3g router is smaller and lighter than an Android and my serial2wifi PCB is very small and light. I also want to use my GoPro Hero2 as cam and i cannot see how i can connect this to an Android for streaming. My solution is simple and stable :-)
  • 3G is what I meant...you guys got the idea.
  • Using 4G should increase data throughput better than 4G.  Experimenting with FaceTime, I noticed the latency is FAR less than it used to be.  I will give this a shot, while staying on the Verizon network, and report back my findings.  Thank you for all the info gents!
  • John,
    I don't think Tommy's system is over complicated. As long as it works and is robust I can't say single bad word about it. But when I'm thinking of letting my Samsung Galaxy S2 handle networking, piloting or anything else for my plane I get bad vibes. It has crashed way too often under pressure to be dependable.
    The less software my plane is using and dependable on, the better I feel about it.
  • it's an autopilot dude - who said it has to be controller manually (flybywire) ?
  • can you actually fly fpv with a 300ms lag? that seems pretty dangerous
