Tersus RTK/PPK OEM Board
1. BX306 RTK BOARD Supports GPS L1/L2, GLONASS L1/L2, and BeiDou B1/B2.Supports in-built 4GB memory, which makes data collection easy.Up to 20Hz RTK solution and raw data output.Supports 384 channels.Pin-to-pin compatible with NovAtel OEM615.Log/command compatible with NovAtel protocol.Supports event mark and PPS.
2. BX306Z RTK BOARD Supports GPS L1/L2, GLONASS L1/L2, and BeiDou B1/B2.Supports in-built 4GB memory.Supports up to 20Hz RTK solution updates and raw data output.Supports 384 channels.Pin-to-pin compatible with Trimble BD970.Log/command compatible with NovAtel protocol.Supports PPS output and event mark input
3. BX316 RTK BOARD Supports RTK positioning mode or RTK positioning + heading mode.The two modes are software configurable.Command compatible with NovAtel protocol.Supports 20Hz RTK solution updates and raw data outputs.Supports 384 channels.Supports in-built 4GB memory, which makes data collection easy.Supports PPS output and event mark input.
4. BX316R PPK BOARD
Supports measurements output (GPS L1/L2, GLONASS L1/L2, BeiDou B1/B2 from primary antenna.GPS L1/GLONASS L2 or GPS L1/BeiDou B2 from secondary antenna).Supports 384 channels.Supports in-built 4GB memory, which makes data collection easy.High integration System-on-a-Chip (SoC) solution.Supports PPS output and event mark input.Serial ports with LVTTL or RS232.External antenna inputs through SMA connectors.
5. BX316D RTK BOARD Supports RTK positioning mode or RTK positioning + heading mode, with software configurable modes.Up to 20Hz RTK solution updates and raw data output.Supports 384 channels.Pin-to-pin compatible with Novatel OEM617D.Log/command compatible with NovAtel protocol.Supports PPS output and event mark input.Supports in-built 4GB memory, which makes data collection easy.
Please check our website for more details: https://www.tersus-gnss.com/product/gnss-oem-boards. Thank you.
Comment
