  • The next DuePi, for use DronPi and Arduino Due... subsequently code for arduino Due + DronPi... INFO
  • Thanks, but it´s completly beyond my manual skills... I´m more a coder.  Thanks anyway. I hope listen more about the project.
  • Hi.
    Manually assemble at home (air + electric welder, solder paste, x10 microscope).
  • Looks very nice and cleanner.
    Did you assembled or sent to some online service?
  • Hi.
    PCB v1.0.5 Mounted, tested with arduino Due (code GitHub)
  • Hi.
    OK, thanks.
    You can find  the PCB in dirtypcbs ,v1.0.5 NO tested !!
    Regards
  • Hi there,
    Despite the tether, autotrim and autotune, do not forget to check the board vibration. Log that and check the accpetable range...
    Nice project! Congrats! I would love have on of those boards. How could I buy one?
  • before you attempt autotune, you need to QUARTER default pids for mini frames. also, you need to lower your min throttle (it has different naming across a few latest ACs) to a value which would just start spinning your motors reliably.
    in most cases mini frame is not the best to try out new flight controllers.
  • Hi, NO AutoTune, yes AutoTrim, sorry, waiting batteries for AutoTune....
    https://www.youtube.com/watch?v=u9ylafJC5bc
    AutoTune — Copter documentation
