What is the maximum range of an Xbee? - Lets find out...
I have recently been pushing the limits of the XBee Pro to see how far it can go.
Unfortunately my current plane (SkyFun) only has a 38 minute duration and a maximum travel distance of 20km, this means the furtherst I have been able to go is 10Km (a 20Km return trip).
I have a 14dB patch antenna which has still shown signal of 85%+ out at this distance.
I wanted to find out how far the XBee could really go.
This meant planning a one way mission.
I spent about a week looking for the perfect start and destination, plotting the course and arranging access to the landing location with a local farmer.
The start point was my normal local park and the landing location was a farm paddock 16Km away.
The flight was over sparsely populated farm land and at a constant incline meaning I could increase altitude during the flight in order to get greater range.
My plan was to launch and monitor the flight from the launch location until I lost contact with the plane via Telemetry. After this I would drive to the landing location where the plane would be circling and manually land.
I calculated that even if I maintained contact with my plane during the flight and it made it all the way that I would still have time to make the 12 minute drive without running out of battery power.
With a tail wind, the plane would average 60Km/h at 45% throttle.
With everything planned and 45 test flights already in the bag with this airframe I was ready.
I launched and the plane took off to the waypoint as planned.
I was hoping for at least 12Km as this was ideal conditions.
The point on the map above shows the point I lost contact which is 10.6Km from the launch location.
The XBee maintained a very strong signal up until the last Km and then it began to drop off very rapidly.
It begins to be unusable below about 40%.
I packed up the ground station and drove to the destination which took just 11 minutes.
The plane was circling perfectly as expected and I put it in FBWA and landed without incident (apart from the slightly startled flock of sheep).
It turns out that the 10Km I had been flying to is around the maximum range of an XBee.
I am working on a much bigger aircraft that will have a 1 hour plus duration at a higher speed so I am going to have to look into more long range options for telemetry. GPRS / cell is preferable as we have excellent coverage here and fully routable and cheap internet plans. However, for experimentation I have been surprised at the distances that can be achieved with an XBee with a cheap patch antenna added on.
Here are a couple of tips for people wanting to achieve maximum range..
 - Minimize antenna cable length. My XBee is mounted on the back of my patch antenna and I run a long USB to my laptop. This maximizes gain and reduces lost signal.
 - I use either the ground or my car to enhance the ground plane effect. Putting the antenna in front of my car door or right beside my car makes a big difference to the distance. Also keeping it as close to the ground as possible.
 - Altitude is king, the higher you can fly the greater the achievable distance. Due to the fact my destination was on an incline, my end waypoint was 400m high relative to my starting point.
- Fly long straight missions so you can line up your antenna properly, I am building an antenna tracker that removes the need for this but Ardustation2 is currently broken since the last Mavlink updates.
Comment by Toby Mills on October 8, 2011 at 12:50am
900RF
I believe they are around 65mW.
Data rate 57600 bps until dropout at about 40% signal strength.
Got some updates on the steen down to about 25% but at a much reduced frequency.
I consider dropout the point where it becomes flakey and I could not reliably send instructions to the plane so around 40%.
Maybe GPRS is an option for you (droncell). I'd still like to see this as a long range telemetry option.
Comment by Janos Haber on October 8, 2011 at 12:53am
Hmm. But GPRS communication is not free, and drain the battery. No?
Comment by Rigel on October 8, 2011 at 12:53am
Toby, how close to your car door and to the ground are you talking about?
If close to the ground, I imagine the antenna would have to be pointed at a decent up angle compared to ground in order not to have the ground interfere with the Fresnel zone, right?
Comment by Rigel on October 8, 2011 at 12:55am
By the way, has anyone found a decently priced 900MHz booster out there?
Comment by Toby Mills on October 8, 2011 at 12:56am
Best result has been 30cm off the ground.
As close to my car door as I could possibly get around 4cm from the panel.
Janos, no not free but relatively inexpensive on a prepay plan.
Comment by Janos Haber on October 8, 2011 at 1:08am
Heheh, you right. But the power drain is still exists... I think it's need more energy than xbee modules...
Distributor
Comment by UnmannedTechShop.co.uk on October 8, 2011 at 5:42am
It is annoying that we cant use 900Mhz in europe, but you could use our xbee telemetry kit.  It does not have the range of 900Mhz, but it is decent enough for around 1Km.  There are some workarounds for using 868 xbees to get over the 10% duty cycle.  Otherwise GSM is the way to go, and if you want to use something the the phonedrone board, with a cheap and small android phone (2nd hand) you could get it working.  But nothing has been implemented yet.
Comment by Jeb Bailey on October 8, 2011 at 6:33am
What kind of transmitter are you using for plane control?  I've never gotten near that kind of range from my RC transmitters.
Comment by Rui Manuel Cravo Marques on October 8, 2011 at 7:08am
Great test, great planning :)
Distributor
Comment by Guto Santaella on October 8, 2011 at 7:11am
Hello Toby,
I have the same question that Jeb did. How could you fly 10Km with RC or you used auto takeoff and landing changing the APM code to fly with out RC signal?
Good job, very impressive
Guto.
Comment
