Hi guys,
I've been recommended these by the helpful chaps over at FirstPersonView (fpvuk.org) as just about the only legal setup available in the UK. ie 25 mW at 5.8 GHz. Toal cost without camera £169.
My question is, the receiver provides 3 rca phono sockets (video and stereo audio). What is the simplest way to get the video signal into a PC so I can display it in flight data?
Thanks very much
Rob
Tags:
sorry, forgot to add the links to the items:
http://www.firstpersonview.co.uk/transmitters/5.8ghz/5.8ghz-25mw-tr...
http://www.firstpersonview.co.uk/antennas/5.8ghz/cloverleaf-antenna...
http://www.firstpersonview.co.uk/antennas/5.8ghz/skew-planar-wheel-...
http://www.firstpersonview.co.uk/receivers/5.8ghz-receiver
Just add camera and video display. £169 for above 4 items.
Thanks to fpvuk.org for above info.
Rob
There is also the tantalising suggestion that one of the stereo audio channels can be used for telemetry. I'm not at all clear what interface hardware would be needed at either end to implement that, and connect to the AC2 firmware like xBee does. But it would mean that one radio link could be used for both telemetry and video, and it could also be done at 2.4 GHz instead of 5.8, if 2.4 was free on your paticular setup.
Rob
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
