I have started to add functions to MinimOsd code.
At first i did it for myself only. Added many functions i thought i need. Then opened this thread.
after a while, Pedro came, and things started to happen fast. :D
He optimised the code and added even more things to it.
He worked hard on CT, and it became a great tool!
Thank you Pedro! :)
Also Burt & Eddie came.
They also worked on it and added many smart things to our firmware.
Thank you!
By now MinimOSD-Extra got a pretty advanced OSD.
Here it is in action:
Added:
- Changeable unit measurement (US, metric)
- Airspeed
- Home alt
- Battery Percent
- Current Draw
- Time From Startup (Will be cleared at takeoff to show exact flight time in the next release)
- OSD Menu
- Variometer
- Wind horizontal speed and direction, and also vertical wind speed (Vertical wind speed will be in next release)
- OSD on/off
- Switchable secound screen
- WP distance
- WP heading
- Warning messages for Lost GPS fix, Stall, Overspeed, battery volt, battery Percent, RSSI
- Efficiency, glide distance & thermic notifier. 3 in one panel (Will be in next release)
- OSD Brightness (Will be in next release)
- HAM Call Sign (Will be in next release)
- After flight summary (Will be in next release)
- Trip distance (Will be in next release)
- Temperature (Will be in next release)
This functions can be turned on and off, and placed on different screens now, by the Config. tool.
Also RSSI, switching mode and channel and unit measurement, Stall speed warning, Overspeed warning, Battery warning volt, Battery percent warning, RSSI warning, can be set in new Config Tool.
We built in a new way of setting video standards. Now OSD does not guessing anymore :). You can set it fixed from CT. It is in "Video Mode" menu.
Here is how it looks: (This video is a bit outdated, sorry. I will make a new one soon.)
About the menu:
I made a menu inside OSD. You can enter this menu only after boot, the same way as screen switching works.
The MinimOSD-Extra project is here: Link
This project is the developing version of the official Arducam OSD located here: Link
The latest stable version is: 2.1
We are sharing it to see videos you make using it! :)
Enjoy
Tags:
Permalink Reply by Gábor Zoltán on July 18, 2012 at 12:42am Found a bug in warnings part.
So here is the version before.
Permalink Reply by Gábor Zoltán on July 18, 2012 at 1:46am I think i have found the bug.
Will fix it soon.
Permalink Reply by Gábor Zoltán on July 19, 2012 at 5:54am It gave me a headache to fix this, but i think i did it.
Now warnings are using only one line to save more useful space.
Also made warning signs blink.
If more than one warnings are triggered, than warning messages are shown alternately. (1s each)
I did work a little on config tool also.
Now warnings can be turned on, and off, and placed anywhere on the screen.
To set the speed limits for Overspeed and stall you still need to use Arduino.
(If airspeed is higher than 100km/h than Overspeed warning appears. Is airspeed goes below 35 km/h, than Stall warning appears. If you don' have airspeed sensor than it refers to ground speed.)
Still not flight tested.
The hex, the mcm, the config tool, and the source is attached.
Please send me feedback.
Permalink Reply by Gábor Zoltán on July 19, 2012 at 4:43am I have an idea on turning OSD on and off in flight without the use of extra channels.
I might do that next.
Permalink Reply by kitegruppe on July 19, 2012 at 5:17am Thx for your Work!
Did you have already fix the Update Chars Boot Problem?
Permalink Reply by Gábor Zoltán on July 19, 2012 at 5:56am Hi kitegruppe,
Well i did not have problems with that.
Actually i have made a few changes in chars also.
Could you explain it with detail?
Permalink Reply by kitegruppe on July 19, 2012 at 6:05am I have flashed your firmware, actualy the best of the avaible i have found.
But also the problem: if i connect OSD and APM2 at the same time, the OSD stopp booting and going in the Char Update mode.
Like: http://diydrones.ning.com/forum/topics/minimosd-says-update-charset...
My minim OSD is hard to acces inside the Plane, so reset is not really an option
Permalink Reply by Gábor Zoltán on July 19, 2012 at 6:17am Did you flash the charset i made for it?
It is called Gabor.mcm
It is in the config tools directory
Try that first. ;)
Permalink Reply by Gábor Zoltán on July 19, 2012 at 6:53am Just read more about your problem.
It seams that this only effects APM2. (I use APM1)
But i have an idea to solve this, if it still present with the latest firmware on your APM2.
So if you still heve this issue;
What is your APMs firmware version?
When does this error kicks in? (Example; It displays Update charset 9 secounds after i turn it on)
Any additional information could help.
I will try to solve this for you.
If i have what it takes, of course.... :D
Commenting out this function, is not a real solution i think.
Permalink Reply by kitegruppe on July 19, 2012 at 7:03am Thx for your Help!
I have an APM2 with Ardu Plane V2.40
"Update Char" comes ~3 seconds after i turn on the System
Permalink Reply by Gábor Zoltán on July 19, 2012 at 7:08am Hmmm....
I think APM is sending some serial data.
I will make a hex for you to try.
Give me a few minutes.
Can you test it now?
Permalink Reply by kitegruppe on July 19, 2012 at 7:09am Ofcourse, the only thing between my Nuri and the Air is that OSD Problem ;-)
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.672 members
24 members
1280 members
182 members
87 members
Powered by
