Hello,
I'm totally new to this. I wonder how to define the speed APM2 uses to fly from one waypoint to another or during loitering. I read about a parameter called cruise_speed, but I do not find this parameter in Mission Planner.
So, how do I set the default speed of the plane?
Thanks and best regards
Dirk
Tags:
Permalink Reply by Michael Pursifull on June 13, 2012 at 8:09pm Do you have an airspeed sensor?
Now, to answer your question, there are several different parameters that control things like the speed range used in fly by wire mode B, and there is a MAVlink command to change airspeed. But what you are asking about is cruse speed used during waypoints, and that is found here (screenshot) TRIM_ARSPD_CM. See also ARSPD_FBW_MIN, ARSPD_FBW_MAX, TRIM_THROTTLE, and MIN_GNDSPD_CM, among others.
Permalink Reply by Max Turnoff on August 22, 2012 at 4:22am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1278 members
182 members
24 members
51 members
179 members
Powered by
