ACRO bug (fixed in 2.9.1b): while doing flips in ACRO mode, if you switch to Stabilize while inverted your throttle will go to minimum. To regain throttle control you need to switch back to ACRO then back to Stabilize again (i.e. switch to stabilize twice). You never lose control of roll/pitch/yaw.
Loiter/AltHold/Auto/RTL bug: if you switch into these modes with throttle at zero motors will go to minimum until you raise the throttle.
Auto mode altitude bug (fixed in 2.9.1b): setting a waypoint altitude greater than 320m over home altitude may wrap around and instead be interpreted as a low altitude.
ArduCopter 2.9 is now in the mission planner and the downloads area!
The major improvement is we use inertial navigation to improve altitude hold. This increased reliance on the accelerometers means you must do some additional set-up before flying:
1. Perform the new accelerometer calibration in the mission planner (video). The auto-trim metho has also changed (video).
2. Add vibration dampening foam between your frame and the APM. Some suggested materials: DuBro, gel, hk foam.
3. If upgrading from 2.8.1, modify the throttle and altitude PID values:
Here is the list of major changes (a more detailed list can be found in the release notes):
As per usual PIDs are optimised for the 3DR/jDrones quad with 850 motors and 10" props. If you're using more powerful motors/props and are seeing bad flight behaviour in stabilize, start by turning down Rate Roll P in 25% steps.
Special thanks to our testing team lead Marco and the dedicated bunch on the 2.8.1 release thread who put their copters at risk while testing the pre-release version. Some of their videos are here: 1 2 3 4 5 6 7 8
Please feel free to report issues you find in the discussion below and/or add them to the issues list.
By the way, if after doing the accel calibration and adding the vibration dampening foam you still can't get good performance please try:
Happy flying!
Permalink Reply by novrizal herdananto on January 18, 2013 at 2:01pm got a couple question:
is this release is the same with RC5 ?
with this accel graph, i should keep my INS_MPU6K_FILTER to 0 right ?
fly tested with my tri, stock pids, except for rate_roll.. alt-hold was very nice.
i personally like to land with alt-hold, just lower the throttle and it will gently descend. once it hit the ground, close the throttle and switch back to stabilize..
any idea how to tune throttle accel P and I ? if is it too high or low ?
Hi Randy,
Got 2.9 running on my Flamewheel with 1/16" thick O-Ring suspension mount on each corner of my APM2 and got results pretty much just like your "Good" results,
Maximum Z excursion in the range -5 to -15. And the X and Y axes also looked similarly clean as in your graph above.
I did reset the MPU6K Filter to 20 as you suggested (default was zero?).
What little vibration is transmitted to the APM board likely mostly comes from the receiver and ESC wires.
The bottom line.
My Flamewheel F450 is flying very well with currently stock as supplied PIDs (I do have -40% expo on pitch and roll on my Hitec Aurora 9).
And suspension O-ring mounting of the APM2 board works at least as well as foam or gel mounting.
Great job on 2.9
Quick question, is the reason the Z axis defaults to approximately minus10 because of the weight of the internal acceleration sensing element (basically gravity)?
Yes, Z will show a force of negative 9.8 m/s^2 (gravity) when it's level. Turn the copter upside down and it will be positive 9.8 (gravity now pointing "up")
Yep, that's gravity.
On your O-ring suspension, I recommend moving the O-ring outboard mounting points outward. I think you may have a problem with roll. Surprised it flies actually. You want a nice wide footprint.
Also, cut back a few of those zipties. Cabling them like that makes the wiring much stiffer.
It would be much better if you could go to a PPMSum output, then you only need 3 wires on the input side. On the output side, you don't need all those wires. I'd try to just get the signal wires, and one set of power and ground, then use an off-board header.
So if you did this, your wiring would be reduced to:
Input: PPM signal, Power, Ground
Output: Ch1, Ch2, Ch3, Ch4, Power, Ground. That's it, 9 wires.
Permalink Reply by Scott Berfield on January 21, 2013 at 2:30pm I really need to buy a PPM cpable RX. If I am powering the APM off its own BEC connected to the input side through the RX, would I still need power and ground connected to one set on the output side? Or could all the ESCs just have signal connected?
Of course then you get to add in the telemetry, GPS and Sonar hookups.
If you use a BEC on the input, then you do not need power connected on the ESC side. So each ESC needs a signal, and a ground. You can use a single ground wire, and then have a breakout which splits it to the ESC's.
However, I strongly recommend you feed the BEC to the APM first, then the Rx. Even though it's more wires. If you go BEC-Rx-APM, then you have 2 failure points for the APM. The APM is the KING. The copter can live if the Rx dies, it cannot live if the APM dies. Power the APM first.
Permalink Reply by Scott Berfield on January 21, 2013 at 3:19pm Makes sense. Thanks.
And one step better, is to mount the "BEC" directly onto the APM. I haven't done this yet, but my new copter I'm building, I'm planning on making like a daughterboard, on which I will mount my 7805 regulator, and the Rx, with fixed connections to the APM2.5. Then there is only one connection to make: Battery to board. Only one likely failure point in the entire input chain. And a JST battery connector is a lot more reliable than a servo connector.
Permalink Reply by steve F11music.com on January 21, 2013 at 4:03pm That sounds like a great idea. I use a 10A BEC castle but now have the power module so was going to the the octo build with that. Now I'm thinking that exceeds the power rating of the power module. Will you be posting the details of your daughter board? I would also like to go that route to eliminate some a failure point. I also want to make the switch to PPM. What rx are you using for that?
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.692 members
51 members
186 members
1298 members
24 members
Powered by
