Attacker GCS for MAVProxy
I am just trying to run the attacker code of the link mentioned. But i am facing the following errors :
MAV> Waiting for heartbeat from tcp:127.0.0.1:5760
Exception in thread main_loop:
Traceback (most recent call last):
  File "/usr/lib/python2.7/threading.py", line 810, in __bootstrap_inner
    self.run()
  File "/usr/lib/python2.7/threading.py", line 763, in run
    self.__target(*self.__args, **self.__kwargs)
  File "/usr/local/bin/mavproxy.py", line 1168, in main_loop
    master.wait_heartbeat()
  File "/usr/local/lib/python2.7/dist-packages/pymavlink/mavutil.py", line 383, in wait_heartbeat
    return self.recv_match(type='HEARTBEAT', blocking=blocking)
  File "/usr/local/lib/python2.7/dist-packages/pymavlink/mavutil.py", line 344, in recv_match
    m = self.recv_msg()
  File "/usr/local/lib/python2.7/dist-packages/pymavlink/mavutil.py", line 318, in recv_msg
    msg = self.mav.parse_char(s)
  File "/usr/local/lib/python2.7/dist-packages/pymavlink/dialects/v10/ardupilotmega.py", line 9257, in parse_char
    self.__callbacks(m)
  File "/usr/local/lib/python2.7/dist-packages/pymavlink/dialects/v10/ardupilotmega.py", line 9234, in __callbacks
    self.callback(msg, *self.callback_args, **self.callback_kwargs)
  File "/usr/local/lib/python2.7/dist-packages/MAVProxy/modules/mavproxy_link.py", line 347, in master_callback
    self.set_prompt(self.status.flightmode + "> ")
  File "/usr/local/lib/python2.7/dist-packages/MAVProxy/modules/lib/mp_module.py", line 148, in set_prompt
    if prompt and self.settings.vehicle_name:
  File "/usr/local/lib/python2.7/dist-packages/MAVProxy/modules/lib/mp_settings.py", line 108, in __getattr__
    raise AttributeError
AttributeError
I am not an expert in python so please do help me out to solve these errors.attackerGCS
  • Why would you expect someone to help you with this?
    Are you white hatting/pen testing?
    This is irresponsible. It's also a pretty poor implementation.
